02-15-2018, 09:10 AM | #1 |
Rep 13
Help Me Get Rid of This Rust
Hey Everyone,
I've been lurking here for some time and recently bought my '14 328 and absolutely love the thing. But after picking her up from the dealer, I noticed some rusting on the brakes. It's not on the disk or really anywhere that would remove the rust by driving, and I want to get rid of it as it's unsightly and I don't need it damaging the car in any way. I was thinking a simple wire brush would do the trick, but I know you all know better than I do. Here's a (massive) pic: As you can see the rust is just in front of the disk... Embarrassed to say I don't know what the name of that part is... |
02-15-2018, 12:21 PM | #2 |
Rep 1,572
That's the normal rust on the hub and un-swepted portion of the rotor. You can clear with wire brush, steel wool, etc, but unless you paint or powder-coat that area, it will come back. Just the nature of untreated iron.
ThatOneShortKid3.00 |
02-15-2018, 12:35 PM | #3 | |
Rep 13
Thanks a ton for the guidance. |
02-15-2018, 02:35 PM | #4 |
Rep 1,572
There are several threads on here regarding painting calipers and rotors. Also if you do a google search on : "Painting rotor hubs", you will get a slew of hits. Some folks warn that if you paint the rotors hubs (non-contact surfaces) you may have to have your wheels re-balanced, but unless you really fail at a uniform spray pattern, I doubt that will be an issue. Have fun!
02-15-2018, 02:48 PM | #7 |
Rep 13
02-15-2018, 02:59 PM | #8 |
Rep 3,539
I used silver high-temp BBQ paint from a rattle can at the local hardware store. Matches the OEM zinc finish well.
02-15-2018, 03:01 PM | #9 |
Rep 216
02-15-2018, 03:08 PM | #10 |
Rep 13
02-15-2018, 03:09 PM | #11 |
Rep 13
02-15-2018, 03:15 PM | #12 |
Rep 216
The original finish remains, you just use the tin foil as an abrasive to remove the rust. The rust scrapes off and the foil is softer than the metal so it wont scratch.
02-15-2018, 03:42 PM | #13 |
Rep 13
02-15-2018, 03:53 PM | #14 |
Rep 216
Nah. Just cleaned it up. I'm sure the rust accumulated while it was sitting outside in the elements at the dealership. I know it was there for a few months. I'm my garage, that wont be happening as I enjoy detailing my car. Very therapeutic for me
02-15-2018, 03:59 PM | #15 |
Rep 13
Man, I need to clear out some space in the garage for it... I feel bad leaving the car to the elements lol when did you get your car?
02-15-2018, 04:41 PM | #16 |
Rep 216
I got it last month. Still honeymoon phase. Love this car.
02-16-2018, 08:09 AM | #17 |
Rep 13
02-16-2018, 02:12 PM | #18 |
Rep 216
Thanks you too!
View post on imgur.com Mine is the mineral grey one. The other fully spec'd one is a friends. |
02-22-2018, 10:44 AM | #19 |
Rep 351
next time you do brake rotors, buy ones that have that section painted already.
http://www.centricparts.com/products...m-brake-rotors
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold |
02-26-2018, 03:11 PM | #20 |
Rep 153
Drives: 2014 428xi Sport Line
I have the same issue however I cleaned the rotors and painted them with G2 caliper paint.
They look good however after a good rain I get rust water coming from the between the rotors as the vanes are also rusty. I was about to pull the trigger on some R1 Concepts Geomet rotors. Has anyone had any experience with these rotors? |
03-01-2018, 09:09 PM | #22 |
Charles B
60
Rep 84
Drives: 335 M235 Z4 944 Turbo
The easy way to fix this is to use a small wire wheel in a drill, go over the hub and remove the rust, and spray paint it with Zinc based paint. Rust here is normal.
brake rust, rust |
