10-26-2016, 05:46 PM | #1 |
Rep 700
10k on Michelin AS/3?
Went in for a rotate and balance on my car yesterday and the guy at discount tire told me my rear tires were already down to 5/32s on the treadmill depth. I got them put on last Halloween, so I didn't even get a full year out of them. I have a 328d, so I don't believe my car is heavier than a 335i, so I don't think the weight is an issue. I haven't tracked the car at all, and he said that it was even wear all the way across the tire, so that just leads me to think that they actually did wear out that fast. Anyone else run into this before who has ran these tires?
10-26-2016, 07:45 PM | #2 | |
Rep 4,980
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
IndotagSwizz524.50 |
10-26-2016, 07:48 PM | #3 | |
Rep 3,943
10-26-2016, 09:32 PM | #4 |
Rep 700
I got 45k out of my factory P7's, and I drove on those far worse than I have the Michelin's. My only problem with it is that they have a 45k tread wear warranty, so I at least assumed I'd get longer than a year out of them. If this is what I can expect out of running a staggered set up, I'm going back down to a square 18 set up.
10-26-2016, 11:32 PM | #5 | |
Rep 3,622
BMW CCA Member #516012
10-27-2016, 07:13 AM | #6 | ||
Rep 4,980
10-27-2016, 09:50 AM | #7 | |
Rep 700
10-27-2016, 10:16 AM | #8 |
Rep 1,231
this is so, any high performance tire will wear faster, their compounds are a lot more soft in order to make the tires stick well, there are other tires you can get if you want them to last longer but their compound will be a lot harder and they will not come close when it comes to stickiness
10-28-2016, 01:38 PM | #9 |
Rep 10,346
I'm replacing my S001 (31k miles) with the PS A/S 3 (Thank you Costco). There's no reason why you should only get 10k miles.
BTW the tread warranty is halved on staggered setups.
"Drive more, worry less. "
10-28-2016, 05:15 PM | #11 |
Rep 700
They can only get rotated side to side being staggered, but they only got rotated and balanced twice. I know that say, the PSS would be averaged around this, but I figured going to an all season, I'd get a little longer life out of them.
11-03-2016, 08:31 PM | #12 |
Rep 191
Drives: 2013 BMW 335i M-Sport
I see your from Houston.... our roads would probably explain the quick wear
I just did the AS3 255/40-18 squared, I plan on rotations from Discount every 5k.
2013 335i M-Sport 8spA
2011 M-B GLK350 2000 Dodge Ram 2500 QC 4x4 CTD |
11-03-2016, 08:39 PM | #13 |
Rep 700
That could be one thing, but with the fronts being down less than half tread as well, I feel it may be the tires.
