02-11-2017, 05:08 AM | #1 |
Rep 597
Does Shockware reset coding?
Hey all,
Looked for and couldn't find an answer to this - does having Dinan Shockware installed at the dealership reset coding? What about VO? If it does, will I erase the Shockware if I reflash to 2TB in VO after? Just want to be sure all these things play nice before I head in and have this installed. Thanks, tgm |
02-12-2017, 02:05 AM | #2 |
Rep 8,364
Generally, tunes are rooted deeper in software.
What do you mean by reflash to 2TB? Flash programming is different than coding. Are you planning on coding DME for some reason? |
02-12-2017, 05:29 AM | #3 | |
Rep 597
I'm also going to eventually pickup bootmod3, but I'm assuming that since I will already have Shockware that their flashes will keep it. Is this incorrect? Just trying to ensure I don't wipe Shockware once I get it, especially once I move to bm3. Thanks for the help, tgm |
02-12-2017, 08:52 PM | #4 | |
Rep 8,364
I am not familiar with all the various tunes. Just ask installer which modules they coded. For example, if they are flash programming DME (engine ECU), then VO or FDL coding EGS, ICM, and KOMBI for 2TB will not affect tune. |
02-12-2017, 09:17 PM | #5 | ||
Rep 597
I'll reach out to the bootmod3 guys and see what they say. Hopefully any changes from Shockware are read and saved when the ECU is unlocked prior to bm3 install. Thanks for the info. -tgm |
02-12-2017, 10:09 PM | #6 | |
Rep 8,364
02-12-2017, 10:22 PM | #7 |
Rep 1,805
no it doesn't.
just had it done a week ago
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
tgmsocal156.00 |
