BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 JB4 Stage2 Dyno Testing
      03-20-2013, 09:57 PM   #221
tdizzle
Drives: 2017 F80 ZCP
Originally Posted by mikew2069 View Post
the pdf on the bottom of the first post here has the instructions... http://www.n54tech.com/forums/showthread.php?t=18588
I forgot I actually found that yesterday and had it sitting on my desktop. Not as great as the video I found for Stage 1, but I'm sure with everything in front of me it would be straight forward.
What sort of connection did you do for the power? Just tap into the jumper terminal or something more permanent?
      03-22-2013, 09:24 AM   #222
spideypm
Drives: 2013' 335i M Sport
Ran into a system lockdown on my car with Stage 2 Map 2 today. I had experience with a lockdown before with stage 1. With stage 1 it happened after 2 hard runs... the warning came on my screen and told me to drive back to dealer for a check-up. My car was limited to 1000 rpm. After i turned off my engine and turned it back on. I waited 2 mins for the light to disappear and drove normal again. Today it happened when I was driving normally on a highway. Prior to the lockdown I noticed Map 2 sometimes does not feel smooth while driving. Feels like it was a glitch and could happen at low speed. Feels like the acceleration skips a little bit. I felt it couple of times driving on high way around 70 miles an hour. Today as I was picking up speed up to 70 miles it happened again and came the lockdown. What should I do?
      03-22-2013, 09:55 AM   #223
NICKTENN
NICKTENN's Avatar
Drives: 340i M Sport
What octane & manufacturer gas are you using?
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP
      03-22-2013, 10:03 AM   #224
spideypm
I'm in Taiwan. We have so-called 98 unleaded here.... which i think is closer to 93 octane...
      03-22-2013, 10:22 AM   #225
NICKTENN
NICKTENN's Avatar
Wow!! I guess you'll just have to wait for Terry to respond. Does he know your in Taiwan? I wonder if coding/language is different.
      03-22-2013, 02:11 PM   #226
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
2014 Audi SQ5  [0.00]
I've decided not to install a downpipe and no longer have any real desire to keep my stage 2 upgrade kit. If anyone is interested I'm selling it for $150 shipped. I have a post in the classifieds as well.
      03-22-2013, 03:19 PM   #227
NICKTENN
NICKTENN's Avatar
Tdizzle, jump on that!
      03-22-2013, 04:38 PM   #228
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
Originally Posted by Bowser330 View Post
I agree that the V10 has the rpm and thus gearing advantage versus the N55 however since the tuned N55 has so much more torque than the V10 its not as simple as "gearing wins"...
Example:**
V10 300wtq 10:1 ratio = 3000 multiplied wheel torque
I6TT 440wtq 7:1 ratio = 3080 multiplied wheel torque
So yes the M5 could rev higher and thus stay in a lower gear (10:1) giving it better torque multiplication. However since the N55's torque is so much more ( ~50% more in the low & mid range) even at the higher gear (7:1) the multiplied wheel torque for both are equally matched...now add the fact that the load is 500lbs less on the 335i (3590 vs 4090) and the 335i should accelerate faster with the same amount of multiplied torque...
** The "wtq" figures are relatively accurate, however the gear ratios used are example only, used to illustrate the point that an engine with more rpm isn't always faster; rpm, gearing, torque, and weight all matter.
Don't forget area under the curve...
ERnie
2016 BSM/f80/ZCP
      03-22-2013, 06:05 PM   #229
RollingLower42
RollingLower42's Avatar
71
Drives: 2012 BMW 335I
Anyone have a link to the software you are suppose to DL, in order for you to run stage 2? I have to take my car to LTMW tomorrow morning, and I need to DL the application so we can access map 2..
      03-22-2013, 06:44 PM   #230
spideypm
http://www.n54tech.com/forums/showthread.php?t=13189
this is the interface that I use.
      03-22-2013, 08:33 PM   #231
tdizzle
Originally Posted by spideypm View Post
Have you fixed your issues? I think you were the one that mentioned you had basically limp mode issues right?
      03-22-2013, 09:56 PM   #232
spideypm
Yes..... I've traded emails with Terry and I'm going to log couple of runs for him to check. He mentioned that it happened to their test car one time with DP correspond to what happened to me. I had it happened to me once with stage 1 and now stage 2. Both times I had the DP on... Stage 1 was right after hard runs and this time it was on normal driving. I have the Challenge HFC DP .
      03-22-2013, 10:00 PM   #233
tdizzle
I'd appreciate if you kept me posted. I was thinking I may go with the Challenge HFC and Stage 2 later on in the summer.
      03-24-2013, 08:30 AM   #234
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Knock on wood - I have the Challenge HFC DP as well and no issues yet. Drives like a beast but I've only pushed it maybe 10-12 times are so. How often do you get on it?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      03-24-2013, 09:27 AM   #235
spideypm
Not too often at all.... like I said... it happened to me with stage 2 when I was driving normal. I'm wondering once you are on Map 2, can you still use the steering wheel to change it to map 0?
Do you ever notice your normal acceleration to be not smooth? I think it doesn't happen every time but sometimes driving on the street I would feel like the car just kicks....
      03-24-2013, 01:08 PM   #236
Petro914
Petro914's Avatar
Drives: F30 335I M Sport
Stage 1 all else stock.. I was in limp mode (limited rpm) after 2-3 days after install. It happend after a hard run when shifting from 2nd to 3rd from a dig. I parked the car at home, turned it off and back on and the light was off. The next morning on my way to work in came back on while in traffic. On my way back home the light appeared to be gone again. I decided to test my luck - I spotted and smoked a Evo on the way home that day and hasnt come on since. I beat this shit out of it everyday
Just yesterday gave a cts-v coupe with one other person in his car a bitter surprise.. couldnt keep up or pass from a 10-15 mph roll onto a highway. He was def. surprised I love this car
      03-24-2013, 01:11 PM   #237
tdizzle
Good lord, what year cts-v?? I love my 335i but wouldn't expect it to be that close to a new cts-v given the fact that it has about 200hp on our cars.
      03-24-2013, 01:22 PM   #238
Petro914
Petro914's Avatar
Not sure what year to be honest. He was riding my a$$ getting onto the highway and we both jetted once it opened up. I may have had a one second jump on him when the median opened up but I'm sure he was surprised he couldn't come close to passing me after a 15 second run or so. This thing has balls with such a simple upgrade.
      03-24-2013, 01:49 PM   #239
tdizzle
Pretty impressive. Ran any 0-60 or 40-80 runs? Or anything like that to compare between stock and stage 1?
It looks like Nick didn't see much of a difference in his quarter miles, which surprised me. I just installed it and haven't had much of a chance to get more than a 'feel' at highway speeds. It seems to move a bit better but really hard to say. Once it drys up I'll do some runs and video them to compare against my 0-60 and 40-80 and 60-80 runs. The one run I did from 20-60 I got wheel spin and traction control intervention, not sure if more due to the increased power or the damp road.
My not scientific testing showed I was getting in the 4.8 range from 0-60 stock though. I need a vbox...
      03-24-2013, 01:49 PM   #240
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
These cars are fast. I keep walking New 5.0 GT Mustangs. I know they should be faster but I love the look on their faces.
      03-24-2013, 03:25 PM   #241
anelson524
Drives: '15 AY F80
2015 BMW M3  [0.00]
I ordered a GTech Pro, has anyone had any experience with one of these vs the vbox? I imagine the vbox is superior but for the difference in price the GTech seemed like something worth trying out. They also don't have a restocking fee like the vbox if you decided to return.
      03-24-2013, 03:37 PM   #242
mikew2069
mikew2069's Avatar
413
No mine seems to be very smooth. Just the occasional whiplash when I stomp on it
I also haven't timed anything but my main concern is traction. Any time I get on it from 25mph or lower, I definitely spin the tires so I know thats going to hurt the times.
BM3/H&R/Borla
