04-19-2018, 08:45 PM | #1 |
391
Rep 449
Video - F30 Brake Flush and Bleed
Hey Everyone,
Here's a video on how to flush and bleed your brakes on your F30 (truth be told, it's a very similar process on most cars). Hope this helps! Bryan |
04-27-2018, 04:44 PM | #2 |
No 55mph
1621
Rep 8,476
Does this procedure apply if you install new calipers & hoses or would you have to go to dealer for that so they can activate ABS to bleed?
I would think if you clamp off the hoses, remove old calipers, then remove hoses from old calipers, install new calipers with hoses already attached, then quickly disconnect the hard line from old hose & reconnect to new hose that air would only be introduced from hard line connection point out thru caliper & not affect ABS system - so this bleeding procedure would suffice?
04-29-2018, 01:27 PM | #3 | |
Rep 204
