BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Coolant Light Keep Coming On After Replacement of Sensor
European Auto Source
      01-22-2013, 09:27 AM   #1
legaleye3000
Drives: 2014 328i; 2015 X3
I just had my car in the shop. They replaced the coolant tank that has the sensor on it. After testing, they said that the replacement was bad. Then they replaced it again and now my coolant light keeps coming on.
Any ideas?
      01-22-2013, 01:53 PM   #2
shivj
Drives: 2012 F30
Misunderstood, but the tank was replaced twice or the sensor was? When you turn the heat on does it get hot? Any issues with overheating at all?
      01-22-2013, 02:23 PM   #3
legaleye3000
They said they replaced the tank twice (during the same visit to the dealership; not to different visits). No overheating issues... I haven't turned the heat on since I'm in south FL and need the a/c
      01-22-2013, 02:41 PM   #4
shivj
Drives: 2012 F30
Ah my mistake, missed the location. Well if cooling system is functioning properly, perhaps there is some sort of a short on the sensor lead. Sorry I can't be of more help. Still getting used to how nearly every aspect of these cars is computer controlled. Another trip to the dealer perhaps? Best of luck!
      01-22-2013, 02:42 PM   #5
legaleye3000
If a sensor is replaced, is a sensor lead also replaced? Thanks!
      01-22-2013, 02:57 PM   #6
shivj
Drives: 2012 F30
Not entirely sure on bmw's, but on my s2000 the same lead would be reused and just the sensor at the end replaced. Looking at the previous generation 3 series it is similar, so I imagine the F30 would be as well. However, I have seen that a few people with F30's have had faulty coolant sensors, which were of course replaced by the dealer. That's the only thing that pops into my head regarding the light coming on
      02-02-2013, 04:22 PM   #7
Hilbe
Drives: F30 320 2013
What color is your coolant? Service repulaced it and now the temperature goes up.
Now the coolant is blue but i think it was pink when i got the car
      02-02-2013, 08:52 PM   #8
Robz_328i
Drives: Bmw 328i 2012 Luxury Executive
By the way a question like this, I live in montreal canada which is pretty cold. Do someone experience this but it takes about 10mins for the car heat to get hot? Sorry i was driving a volvo before and it became hot pretty quick. My 328i seems to take time though but might be normal ???
      02-02-2013, 08:53 PM   #9
Robz_328i
+ my coolant did came up too. However when i went to bmw, they added some more and it eventually did better than before. Never saw the smg again.
      02-02-2013, 10:51 PM   #10
legaleye3000
I found out that the dealership didn't secure the hose that connects the tank to the engine so a couple hours later it fell off of the tank and all the coolant spilled out causing my car to overheat!
