05-01-2017, 08:04 AM | #23 | ||
Rep 19,982
05-01-2017, 08:30 AM | #24 | ||
Rep 32,881
05-01-2017, 08:40 AM | #25 |
Rep 9,709
Sure, but in the context of stopping 1.7 tons of speeding metal, the extra inertial forces of 30-40Kg's of rotating mass is minimal. See how quick a bicycle wheel stops when spinning in free air, it's almost instant.
05-01-2017, 08:49 AM | #26 | |
Rep 32,881
Inertial force explained here by someone far more intelligent than me: http://www.school-for-champions.com/...m#.WQc8I4HTXYU |
05-01-2017, 09:20 AM | #27 |
Rep 5,897
Drives: 2014 335i Black F30 M Sport
05-01-2017, 12:58 PM | #28 |
Rep 66
Wow, thanks for all these comments, really learning lots. Perhaps I have not got used to the way the car behaves yet, I have only had it two or three weeks. My previous car a 123d I had for several years and I got to know exactly what it would do. I haven't started to drive the 330 hard yet, will be able to make a better judgement then.
Again, thanks for all the information, brilliant. |
05-01-2017, 04:06 PM | #29 |
Rep 8,495
There are a lot of forces and variables operating on the car and these are not constant as speed changes.
As speed increases the total energy transferred into the vehicle rises (non-linear; I'd guess by the square of the speed) so the braking system has a huge amount of work to do as speed increases. The components in a big brake system provide several benefits : larger diameter discs provide greater retardation for a fixed pad area and pressure; larger pad area and higher performance pad material increases the friction coefficient and ability to perform at higher temperatures; thicker ventilated discs and (with the StopTechs) swept internal vanes provide greater air through flow and cooling. Tyre/road friction coefficient does not remain constant with speed, once the effect of weight-transference under braking is factored-in. Hence why BBKs are often sold for the front only. I find the most noticeable improvements to be brake feel, greater progression and control due to the improved performance, and (so far, on the road) no fade. High performance pads in an MPerformance setup may perform very well, but I didn't go down that route. I've found that better pads (EBC Yellow Stuff) provided incrementally improved performance. The StopTech BBK improves the performance by an order of magnitude.
05-02-2017, 04:18 AM | #30 | |
Rep 520
Reaction times would have to be ruled out though, so we'd need to choose some fixed points of reference |
05-02-2017, 04:49 AM | #31 | ||
Rep 19,982
Depending on the speed at which we start braking too, the test will only be repeatable a few times too for yourself before it's a test of braking endurance. The other factor is I'm now running PS4S tyres and I'm pretty they will up the level of braking force which can be applied.
05-02-2017, 04:54 AM | #32 | |||
Rep 19,982
05-02-2017, 05:09 AM | #33 |
Rep 520
Not interested in technique, we can all stand on a brake pedal with the same amount of force Purely interested in the shorter stopping distance a BBK gives you
05-02-2017, 05:12 AM | #34 |
Rep 19,982
Well that's not true either, though I make no claim on my own braking technique, as I know it could be improved considerably on track days. Probably safer if you fancy taking my car out and trying the brakes for yourself.
05-02-2017, 05:37 AM | #35 |
Rep 520
Thanks, that's a generous offer but that wouldn't tell me how many metres shorter stopping distance at x/y/z given speed etc. Pedal feel doesn't equate to stopping distance
