03-25-2020, 04:25 AM | #1 |
Rep 55
Obd Bluetooth adapter for beemer code.
Hi guys,
I'm wanting to download beeme code for my 16 plate 435d. Do I need to back up normal ECU incase I mess up coding/code something wrong or the car throws a wobble? Also i have the tourqe pro bloothooth adapter small blue one was about £5 I'll attach a picture will this be fine to use will it be compatable or do I need to order a specific one? And will my stage 1 map be safe. Cheers. Last edited by Ron435d; 03-25-2020 at 05:00 AM.. |
03-25-2020, 06:15 AM | #2 |
Rep 65
Bimmercode requires you to have one of their chosen adaptors, so yours won't work.
https://bimmercode.app/adapters/ That's the list of adapters. Last month I bought the icar Pro https://www.amazon.co.uk/dp/B071D8SY...302_E_DDE_dt_1 It says no longer recommended on the bimmercode site, but I used it to code a bunch of stuff on my 16 plate 330d. As for backups, I believe the app does it automatically. |
03-25-2020, 08:32 AM | #3 | |
Rep 55
Cheers mate appriciate it. Will my map be safe I take it. |
03-25-2020, 08:54 AM | #4 |
Rep 2,815
Drives: F33 430 and F39 M35i
i have bm3 stage 1 tune and have coded with bimmercode afterwards, no issues.
03-25-2020, 08:59 AM | #5 | ||
Rep 1,502
Drives: F36 435xd
And your map is safe. As far as I know it cannot read/write to ECU.
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
03-25-2020, 10:12 AM | #6 |
Rep 55
Perfect cheers lads, do you know the active sound option does this only apply to cars fitted with an active sound exhaust or can you change the sound without one I understand it comes threw the speakers but always wondered if it only works with active exhaust fitted.
03-25-2020, 11:17 AM | #7 | |
Rep 1,502
Drives: F36 435xd
ASD is the one making fake engine sound from the speakers. As far as I know, Active sound from the exhaust is only by retrofitting M performance exhaust or 3'rd party products on the 3/4 series.
Brgds
03-25-2020, 12:07 PM | #8 | |
Rep 55
03-25-2020, 12:13 PM | #9 | ||
Rep 1,502
Drives: F36 435xd
Funny, I have been looking at Cobra too. Do you have any idea of the quality of Cobra products?
Brgds
03-25-2020, 01:49 PM | #10 |
Rep 16,140
03-25-2020, 04:49 PM | #11 | |
Rep 65
The one OP has looks to be some generic OBD adapter. |
03-25-2020, 04:59 PM | #12 |
Rep 16,140
I bought a VGate last April, when it was still on the Bimmercode approved list. When I got around to using Bimmercode in August it wouldn't work with the VGate, giving me a message that the VGate was incompatible. It then pointed me to Veepeak, even including a discount coupon code. That told me that Bimmercode was getting a kickback from Veepeak, but VGate wouldn't play ball, and they rendered VGate incompatible as a result. I can't say if other non-recommended adapters will work, but there's nothing to lose in trying it.
03-25-2020, 05:08 PM | #13 |
Rep 65
Really? Bizarre. Mine didn't play ball at first but I had to try connecting twice and it worked fine. This was in Feb 2020. Successfully coded a bunch of stuff onto mine. Odd that yours didn't work
03-25-2020, 09:32 PM | #14 |
Rep 16,140
It didn't work, and it wasn't a connection issue. It had to connect to tell me that it was not a compatible dongle and that I had to get one that was.
03-26-2020, 07:36 AM | #15 | |
Rep 55
As for the cobra tbh I've never had a problem with them I had there system fitted to my mk2 RS and was amazing couldn't fault it. Also there customer service was amazing always went out there way to help even talked about costom work they were open to it so yh my experience has always being good. Cheers |
03-29-2020, 09:30 AM | #16 | |
Rep 1,237
Can confirm. JUST used vgate icar pro to quickly and seamlessly code my 2013 328i with bimmercode. It definitely still works as an adapter. |
03-29-2020, 10:22 AM | #17 | ||
Rep 1,502
Drives: F36 435xd
Might pull the trigger on a back box from Cobra then
Brgds
beemercode, bluetooth, obd |
