05-24-2017, 07:28 AM | #45 |
Rep 201
I'm still waiting for deliver of my 340i. However I did test drive one a little over a month ago and it sounded like it had the ASD. I then test drove a 340 GT about 2 weeks later and i didn't hear it. The ASD actually sounded really good in the 340i and the GT just didn't seem as fun without it. I had a similar feature in my golf r but it sounded like crap and I ended up disconnecting it.
05-24-2017, 11:37 AM | #46 |
Rep 4,447
Notice it on mine, don't like it.
Easy way to tell - stick car in Sport and move stick to the left, listen to the engine noise. Leave stick in the left and change driving mode to comfort - revs will stay the same as you're in manual mode but the drone noise goes away. |
05-24-2017, 11:43 AM | #48 |
Rep 4,447
05-24-2017, 11:52 AM | #49 | |
Rep 962
ASD module has sound levels that can be changed. As of the recent I-Step, there is even an option for "Gear Change Sound". |
05-24-2017, 05:04 PM | #50 |
Rep 349
It does sound good inside the car with the windows closed
2017 340i - ZMT, ZTR, Z11, Z08
05-24-2017, 09:58 PM | #52 |
Rep 25
Trying to get it working...
seems like it's maybe tied to the VIN which is programmed in the ASD module. I put a F80 M3 ASD module in my 2012 328i and it's only allowing the F80 S55 found. Won't play anything else. I'll keep you guys posted if i figure it out |
02-26-2018, 11:31 PM | #53 | |
Rep 268
But I can confirm MPPSK is turning ASD off. Mine had mppsk fitted and asd is coded off, and can not be turned back on. I've tried recoding back to stock B58 and other M3/m4 engine combination, nothing works. ASD software version looks different as well, Defo gone with mppsk |
Blubaron791430.50 |
02-27-2018, 10:04 AM | #54 | |
Rep 962
02-27-2018, 01:28 PM | #56 |
Rep 268
11-06-2020, 11:38 AM | #57 | |
Rep 203
Is there any confirmation that MPPSK turns off ASD ? Thanks
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
11-16-2020, 01:06 PM | #58 |
Rep 203
Update: after having bought the Bimmercode app and deactivated the ASD, I would say that I can hear a slight difference: the car is a little quieter, especially in confort mode.
But the change is not huge and the tone is rather similar. So MPPSK doesn't deactivates ASD, but on b58 engines, the effects of ASD are not drastic.
11-19-2023, 05:04 AM | #60 | |
Rep 10
I can’t seem to get my 435 ASD to work. |
