05-24-2017, 11:34 AM | #23 |
Rep 32
I tried with 3 different PC and 2 cable. One of them was my friend's coding laptop. So that's why I want to focus on the car now.
08-05-2017, 07:02 AM | #24 | |
Rep 1,555
08-05-2017, 08:18 AM | #25 |
Rep 40,668
You will not be able to connect via VIN unless PSdZData is properly installed, and the Car and Laptop have a connection. For this:
1) The Target Connection Window should not be blank (It should show multiple target connections for different chassis') 2) ENET Cable must be good and making good contact in OBDII Port 3) Car must have proper voltage (Make sure motor is running if car is not on a Charger). 4) Laptop must not have Firewall or any Antivirus software running. 5) PC Lan Adapter should get a fallback IP address of 169.254.xxx.xxx (Make sure it is using DHCP and does not have a Static IP address assigned to it)
08-11-2017, 04:10 AM | #26 |
Rep 32
08-01-2018, 12:41 PM | #27 |
Rep 4
I am really struggling with this issue, i have been connected to my car before. Currently i have tested with the ignition on/off, no virus software or firewall blocking anything, the cable has worked a day before so it cant be that, that rules my laptop out also.
I can see all the vehicle profles from psdzdata, i performed a full reinstall or e sys, including the launcher and the psdzdata, but it still wont let me connect via VIN. Does anyone have any othwr suggestions of what i can try? Would very much appreciatw it. C |
08-01-2018, 12:59 PM | #28 | |
Rep 40,668
Is your Motor Running?
08-02-2018, 07:56 AM | #29 |
Rep 4
Hi Shawn,
Thanks for replying, Yes I will have the E Sys cabled connect to the car and laptop with the motor running, and have tried with the motor off also. I have not checked point 5 of post #25, so I will double check that the ethernet connection has a DHCP setting and not static, I haven't touched this since it worked but it is worth double checking. C |
08-02-2018, 09:37 AM | #30 | |
Rep 40,668
08-04-2018, 03:24 AM | #31 |
Rep 4
Performed the winsock reset and restarted the laptop, still nothing. This is the ip address the ethernet connection is getting, which looks correct to me?
Is there any other way to connect to the car with E Sys? I can see the other options aside from Connect via VIN but i assume there is a reason the other options aren't used? C |
08-04-2018, 07:35 AM | #32 | |
Rep 40,668
Try a different laptop. If you have same issue, then it is cable or car gateway module.
08-04-2018, 11:23 AM | #33 | |
Rep 2,302
So you can see if the car is connected to the laptop, because it displays the IP address of the car. If it shows the IP address of the car, then there must be a problem with e-sys. If it does not display the IP address, the problem may be with the cable or the car. |
05-04-2020, 09:19 AM | #34 | |
Rep 40
Same issue here, Ethernet Port is not coming on the laptop side what so ever. Saying cable unplugged. Tried 3 ENET cables and laptops already |
