BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Help!!How to retrofit my new cluster into my F30
      08-28-2013, 02:54 PM   #1
Drives: F30 328
I had upgrade my basic kombi to the S6WAA Instrument panel with extended scope..
Problem is my guy try to retrofit but could find the new cluster detected in his computer to do coding, Anybody here had changed before.could u share with me the way and step to retrofit this cluster into my F30 328..
Help and reply is appreciate...
      08-28-2013, 07:43 PM   #2
shawnsheridan
shawnsheridan's Avatar
First you need to add 6WA to your FA (VO) and write it to the car. Then you need to inject CAFD into Kombi ECU. Lastly, you need to VO Code Kombi ECU.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      08-29-2013, 01:12 AM   #3
Drives: F30 328
Kombi
Thank u so much...I will try and see if can
      08-29-2013, 02:51 AM   #4
Drives: F30 328
We added 6WA in VO, but my guy can not find the "KOMBI" in ECU LISY.
      08-29-2013, 02:56 AM   #5
shawnsheridan
With the Cluster Connected and Powered up, he read SVT, and there is no Kombi or DKombi or Kombi anything?
      08-29-2013, 03:07 AM   #6
Drives: F30 328
If we read svt, then we still can see the BKombi (not DKombi), but if we read ecu, no kombi at all.
BTW, we have added the optical cables and make the MOST ring.
      08-29-2013, 03:10 AM   #7
shawnsheridan
Does BKombi have CAFD with Green Dot next to it, and if so, did you VO Code it with 6WA in VO?
This Kombi is brand new or used?
      08-29-2013, 03:35 AM   #8
Drives: F30 328
Yes, there is green cafd with green dot next to BKombi, but can not even "read coding data", because it is in fact not in the car, if I do CODING the BKombi, a lot of error msg come out.
This 6WA Instrument Cluster is a brand new set.
      08-29-2013, 03:57 AM   #9
shawnsheridan
There has to be something wrong at the hardware level. If the wiring was correct, this Kombi would appear in SVT.
      01-27-2014, 11:15 AM   #10
Serpent720
Drives: F31 328i
Dear Shawn,
I am having a similar problem as Img76, and the ECU is not found even with 6WA in FA. Tried injected the CAF but no success.
F31 328i
13-11-502
Psdzdata 51.1
6WA in the FA
MOST Ring installed
Only BKOMBI (but not DKOMBI) showing in the SVT
HU CIC retrofited (should i restore it back to the original basic Head Unit before 6WA retrofit?)
(With RACE-CHIP TUNE Box installed in the engine), should remove it before flashing the F6WA?
Really hope you may share some idea.
Many thanks in advance
      01-29-2014, 12:11 AM   #11
Serpent720
Drives: F31 328i
Dear Shawn,
F31 328i
13-11-502
Psdzdata 51.1
6WA in the FA
MOST Ring installed
      01-29-2014, 06:00 AM   #12
shawnsheridan
Did you wire 6WA to the Most Bus?
      01-29-2014, 08:52 AM   #13
Serpent720
Drives: F31 328i
Hi Shawn,
Many thanks for your reply.
Yes, the MOST BUS cable was installed from the cluster to the HU.
      01-30-2014, 12:33 AM   #14
shawnsheridan
Retrofitted CIC and Race Chip shouldn't matter at all.
What happens when you Read ECU instead of Read SVT?
      01-30-2014, 03:35 AM   #15
Serpent720
Drives: F31 328i
Hi Shawn, I will try to read the ECU and let you know after Chinese New Year holiday.
Greetings, and many thanks for your kind help!
Cheers
      02-09-2014, 10:42 AM   #16
mougwai
Drives: F30 320I
Hello,
I have similar problem with my f30, we tryed to retrofit 6wa cluster and it is not seen from impa or esys, this is unbelievable ! We added the most ring, bUt does not change anything..
Cluster is connected to the fem through pt can bus, it seems thant the fem does not handle 6wa cluster...
I am working with inpa and you can see easily module connected amp. Cic. Trsvc... But 6wa cluster does not appear !
I suppose that fem is not compatible with 6wa cluster and should be changed ...
      02-09-2014, 11:43 AM   #17
shawnsheridan
What does FEM ECU have to do with Kombi ECU?
When you connect with E-Sys, and "Read ECU" does new Kombi show in SVT?
      02-09-2014, 03:06 PM   #18
mougwai
Drives: F30 320I
Kombi is directly connected to the FEM (or CAS4) by PT CAN bus.
The entry point for diagnose, is the CAS and it does not see the high kombi..
E-SYS/INPA do not see kombi even with FA coded properly.
Kombi gets some informations from the car, i.e kilometers, turn signal, high beam light... but does not work for benzin level, and tachymeter.
Tomorow, i will check error with tool32 from FEM with 6WA instrument connected.
      02-09-2014, 03:14 PM   #19
shawnsheridan
Ok. Good luck.
      02-09-2014, 03:58 PM   #20
mougwai
Drives: F30 320I
Ok. Good luck.
Thanks you !
i retrofited HUD in my F30 car... but whitout 6WA kombi i cannot use this option
I have similar issue with xenon headlight...
0xD90D16 operating unit light (BEL ), ( LIN): wrong version installed
Stupid FEM.
      02-13-2014, 09:34 PM   #21
Serpent720
Drives: F31 328i
Hi Mougwai, are you using 51.1 PsDzdata during coding?
Thanks,
Ken
      02-16-2014, 04:51 AM   #22
mougwai
Drives: F30 320I
Thanks,
Ken
Hello,
I am using 50.4 data.
retrofit done !
I swapped my FEM Middle line to FEM Max.. wired most ring to the Head unit and now i can see 6WA Kombi in E SYS or INPA: if you do not connect Most ring, you will not able to see kombi for coding: HeadUnit must have most ring : my business navigation comes without most ring ! (no matter i replaced by NBT)
I don't know why, I was not able to see 6WA Kombi with my orginal FEM (middle line version)... with HU NBTconnected.
for shawnsheridan, you are familar with cluster retrofit, i retrofited used kombi, and in eeprom, we changed vin to my vin car: but the red dot still there !
Cluster is running fine, we can reset service, can be coded... and in identification from kombi, we can see correct VIN
Do i need to reset Vin using FF byte ?
