12-20-2017, 02:34 PM | #23 |
Rep 66
Can you try taking the car to another BMW dealership, armed with your air quality readout?
You seem to be close to the end of your warranty period - I understand wanting to get this addressed on their dime, but at least with BMW Manhattan - you seem to have hit a brick wall. Ultimately this is a safety issue - and its your own safety that is at risk. If you feel it is an issue with fumes - just take the car to an exhaust shop and have them check everything out. Or an independent mechanic even. Yes it is $$ out of your pocket, you are into the car for $26k and can't get rid of it anytime soon - so best to just get an answer. You have a tool that is showing the air quality in the cabin decreasing - so you aren't just making things up - that decrease in air quality has to be coming from somewhere. |
12-20-2017, 02:36 PM | #24 |
Rep 38
Hi. In my own testing I had it on “A’, “M’, and A/C and than all off and etc Multiple scenarios in Multiple diffrent driving and environment conditions. I really gave this a run as I don’t take a No for answer. That being said, the issue seems to be at worst with “A” on, 75 degrees dialed up, driving 30min in, 30mph and up, windows all up and A/C off, ventilation on Auto direct
12-20-2017, 02:39 PM | #25 | |
Rep 38
12-20-2017, 02:56 PM | #26 | |
Rep 66
If you think that all options are exhausted (no pun intended) at this point - spend a couple hundred $ and have it properly checked out. This isn't something to mess around with. I wonder if there is a higher authority you can appeal to (above BMW) to get some real assistance on the matter (EPA?) |
12-20-2017, 02:59 PM | #27 |
Rep 5,372
I don't need a picture. Tell us the make and model of the testing unit you're using and concentration numbers you're seeing.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
12-20-2017, 03:01 PM | #28 | |
Rep 38
And it looks like no lawyer wants to take my case (even though ford just had to settle for Millions for the same issue) because I was not involved in an accident and not physically hurt/injuries. |
12-20-2017, 03:11 PM | #29 | |
Rep 38
Does this help/work? |
12-20-2017, 03:13 PM | #30 |
Rep 878
Are you sure it’s not the ventilation system. Not a bmw but many years ago I had something similar with a Vauxhall Vectra, was a brand new company car and every time I drove it I would feel tired, my eyes would go red, I’d get a headache and my throat would hurt. Drove with a work colleague who experienced the same. Vauxhall just did the sum of nothing each time it was booked in to look at, I also tried different dealers but again nothing, they just didn’t have the inclination to find out what was going on.
Luckily for me my company decided to pursue it, they hired an expert in the field who came and examined the car, he took the car away and had it for 4-5 hours and he found out what was happening. In my case, the car had AC and the heat exchanger had microscopic holes which under certain conditions would vent the liquid in the exchanger into the cabin via the vents. The report was sent off to Vauxhall, who were also asked to pay for the report, the car went in, the exchanger was swapped out and no more problem. |
12-20-2017, 03:20 PM | #31 |
Rep 16,082
HCHO is formaldehyde, which is outgassed by many man made materials found in cars and a very long list of other items. The same applies to TVOC, total volatile organic compounds. Both are common air pollutants, especially in the city. I don't see the CO that you said you measured.
Katin134.00 |
12-20-2017, 03:26 PM | #32 | |
Rep 38
Link: http://www.industrialsafetyproducts....rbon-monoxide/ |
12-20-2017, 03:27 PM | #33 | |
Rep 10,473
1) Brand Name 2) Model 3) Purchase date 4) New or used That is much more important than 15 posts about tape on your windshield. Is there some reason you cannot answer this? |
12-20-2017, 03:32 PM | #34 | |
Rep 38
https://www.icloud.com/sharedalbum/#B0L5idkMwEXjFZ Also #BillFitz wrote something interesting further up I commented on. |
12-20-2017, 03:38 PM | #35 |
Rep 38
Sorry IK6SPEED if Iam a bit slow replying everyone not right away or miss to incl something. Unfortunately I shouldn’t have posted in two forums. Lol. A lot actually reply to my threads. Thats awesome. ..but anyway , so what was your question again? Sorry man
https://www.icloud.com/sharedalbum/#B0L5idkMwEXjFZ Device: https://www.amazon.com/dp/B071LB8MPZ..._kZ9bxrridfcsV And I will upgrade to this: http://www.industrialsafetyproducts....arbon-monoxide Last edited by teamsidney; 12-20-2017 at 03:43 PM.. |
12-20-2017, 03:46 PM | #36 | ||
Rep 10,473
Specification: Test item: HCHO, TVOC, PM2.5. Product Dimension: 150*70.8*43.6mm. Battery Capacity: 2200mAh Lithium Battery. Input: 5.0V/500mA. Charging Temperature: -10℃-45℃. Storage Temperature: -20℃-50℃. Test Range: HCHO:0-1.999 mg/m3. TVOC:0-9.999 mg/m3. PM2.5/PM10:0-999μg/ m3. Quote:
Your device doesn’t measure what you claim. Last edited by IK6SPEED; 12-20-2017 at 03:53 PM.. |
12-20-2017, 04:00 PM | #37 | |
Rep 38
12-20-2017, 04:07 PM | #38 | |
Rep 38
12-20-2017, 04:10 PM | #39 | |
Rep 10,473
Furthermore, to be taken seriously by BMW or a Court of Law, you will need to be able to show that calibration. You are wasting money instead of having an qualified independent 3rd party conduct the test that you can show to BMW, NYT, TV Stations, DOT, State Govt and in a court of law. |
12-20-2017, 04:14 PM | #40 | |
Rep 16,082
https://www.amazon.com/dp/B011O2WW1C...=2895763060101 |
12-20-2017, 04:14 PM | #41 | |
Rep 38
12-20-2017, 04:16 PM | #42 | |
Rep 38
But @Billfitz, what is your take on IK6SPEED last comment further up? |
12-20-2017, 04:21 PM | #43 | |
Rep 38
http://sears.com/uei-test-instrument...p-00957910000P |
12-20-2017, 05:25 PM | #44 |
Rep 16,082
If the levels in the car of formaldehyde and VOCs exceed state or federal regulations and that of the outside air you might have a valid complaint. But you're not going to get a legally binding ruling on a forum.
