BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Weird screeching whistling noise
      02-01-2018, 11:38 AM   #1
F30_n55
Drives: 335i n55
Hey guys i recently purchased a 2012 335i with 50k miles , recently the ofhg blew and got that replaced . Now outta no where i am getting this whistling screeching noise from the motor at low rpms 1200-2400 i provided a link to a video if anybody can point me in the right direction...
https://flic.kr/p/23YzQvX
      02-01-2018, 11:48 AM   #2
BunkerJ
BunkerJ's Avatar
621
Drives: 2013 328i
Sounds like you have a vacuum leak somewhere. I believe there is a post or two on here on how to make a really cheap tester for this.
Secondary could be something rubbing or a belt going bad?
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      02-01-2018, 11:52 AM   #3
F30_n55
Drives: 335i n55
I have took the car to the dealer ship they have replaced the tensioner, some pulleys were replaced not sure which ones outta the top of my head need to see my paper work, a v belt and car is still making this noise
      02-01-2018, 12:14 PM   #4
gup
Drives: f20
check your blow of valve
      02-01-2018, 12:46 PM   #5
F30_n55
Drives: 335i n55
Will do what should i look for
      02-23-2018, 06:56 PM   #6
BunkerJ
BunkerJ's Avatar
621
Drives: 2013 328i
Sorry, forgot about this.. Not sure if you still have issues, but check all vacuum lines and chargepipes.
