BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > car burning oil
      04-07-2013, 10:37 AM   #1
godfather87
Drives: 2013 335ix
car burning oil
hi guys,
I was prob 200km away from home last night and the low engine came on...it was at the minimum mark, everything was closed and i had no choice but to drive it back to home and ruin my weekend plans...i have 13k km mileage on the car..but is it normal for the car to burn this much oil? i find it odd that i burned oil, i didnt drive it hard at all far as i know...its 90% highway driven so far. what do you guys recommend? Also can i just go to my wallmart and buy engine oil, if so which one would i need? i got a 13 335ix....thanks
      04-07-2013, 10:44 AM   #2
Maz335i
BMW 4 Life...
Maz335i's Avatar
Drives: 2015 SO M3 (on order)
Originally Posted by godfather87
hi guys,
Same thing happened to me and I'm on 12,000 km's only.
Doesn't have much to do with the way u drive.
Curious to know which oil I can purchase rather than wasting time at the stealership on Monday...
MODS: *** / M Sport + Performance / Meisterschaft / Challenge / MORR / more to come! ***
      04-07-2013, 10:56 AM   #3
godfather87
Drives: 2013 335ix
now I'm thinking its all because bmw using smaller engines and turbo to get more power out....
      04-07-2013, 11:21 AM   #4
marseille82
marseille82's Avatar
Drives: 2022 X3 M40i
Originally Posted by godfather87 View Post
hi guys,
It's common, especially with turbo engines. Happened to me last month. Just buy mobil 1 0w40 or castroil 0W30. But are recommended by BMW. From experience the Mobil 1 is easier to find.
      04-07-2013, 12:18 PM   #5
CHCCubs
CHCCubs's Avatar
Latvia
97
Drives: 2013 BMW 328i xDrive Sport
I wouldn't worry about it. My old E90 328i needed a quart about every 12,000km which is about where you are at now.
2013 BMW 328i xDrive Sport Line
Mineral Grey on Everest Grey
      04-07-2013, 02:53 PM   #6
Rhinozeroone
Drives: 2008 335i Convertible
I just keep a case of BMW oil (overpriced Castrol) in the garage. For a long trip, I keep a quart in the car.
      04-07-2013, 09:27 PM   #7
RPM90
Drives: 340i M-sport AT
hi guys,
Turbo engines tend to use/burn more oil than NA engines in general.
Some N55's burn more than others.
Also, newer engines tend to use more oil early in their life as well.
Being a quart low around 7K miles isn't that bad.
More likely your engine will use less oil over time as more miles are put on it.
Others have made good recommendations on the oil you can use from auto supply stores. You don't have to use BMW oil to top it off.
The N55 3.0 has a 7 quart capacity so it has a very large oil supply, which is a good thing.
      04-07-2013, 09:36 PM   #8
Maz335i
BMW 4 Life...
Maz335i's Avatar
hi guys,
Thanks RPM!
Always a pleasure reading your advice. You're always a great help to the international community present on this forum.
Thanks again!
      04-07-2013, 10:30 PM   #9
godfather87
Drives: 2013 335ix
thanks everyone for clearing this up. So is it safe to buy mobil 1 0w40 or castroil 0W30 whicever i can find at my local store and top it up? If i take it to the dealer will they add it for free since bimmer comes with no charge 4 years maintenance?
thanks
      04-07-2013, 11:09 PM   #10
CirrusSR22
Ultimately you want to find an oil the meets the "BMW LL-01" specification. In the US at least, Mobil 1 0w-40 and Castrol 0w-30 are what you usually will find. I believe they are both labeled "European Formula" or something to that effect. But your confirmation will be the BMW LL-01 spec listed on the back of the bottle.
I think BMW will top off for free if you bring it in.
Although, I personally couldn't imagine owning a car and not having top off fluids at home. (Oil, coolant, brake, etc.).
      04-07-2013, 11:12 PM   #11
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I had BMW top me off a while ago...free is good!
SOLD: 2012 335i Mineral Gray
      04-07-2013, 11:13 PM   #12
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
thanks
My warning light came on with about 800 miles on the odometer. I bought Mobile 1 0W40 at Pep Boys because it was a weekend.
I am thinking they did not put the proper amount of oil in from the factory because that is seemingly ridiculous. I now have almost 4000 miles and the oil still shows full.
F30 Sapphire Black M-Sport 335i 6MT
      04-08-2013, 09:51 AM   #13
godfather87
Drives: 2013 335ix
i just had it topped off by taking it to the dealership. no appointment was needed, i just drove in and took less then 30 secs. I'll going to buy some extra oil incase i ever need it in the near future.....
thanks everyone, else i would of been yelling at the dealer for giving me a car that burns oil..haha
      04-08-2013, 10:38 AM   #14
finaloption
finaloption's Avatar
Drives: '13 f30 n26
i keep a quart of GC in the trunk just in case this happens and i'm unable to get to the dealership in a reasonable amount of time
      05-05-2013, 10:22 PM   #15
RPM90
Originally Posted by Maz335i View Post
Thanks RPM!
Thanks again!
No problem, and thanks for the comment.
Sorry this is so late, I haven't been in this topic in a good while.
      05-06-2013, 08:11 AM   #16
Maz335i
BMW 4 Life...
Maz335i's Avatar
No problem man, been only a month!
      06-29-2013, 03:08 AM   #17
dudespb
dudespb's Avatar
Russian Federation
Drives: E92 335i JB4 AT
It was a problem with old <2010 N52B25 engines. Faulty parts were replaced later. I've never heard about problems with N20 in F3X cars.
      06-29-2013, 03:10 AM   #18
dudespb
dudespb's Avatar
Russian Federation
You have to check your N55 engine if there's no leaks. This engine must not burn more than 1L per 5k km.
      10-06-2013, 11:15 PM   #19
gonein10
gonein10's Avatar
Drives: 2013 x5D 2014 435i
so i've seen a couple of complaints in regards low oil.
and i understand that there is no dip stick so that you can confirm oil level in the traditional manner. Which would tell you exactly what the level is at.
therefore everyone is relying on the computer, which monitors and displays max and minimun oil levels.
is it possible that the oil level, on some vehicles, was never 100% capacity to begin with?
