11-07-2012, 05:17 PM | #1 |
Rep 4,939
Drives: 340i MPPSK
Flat tyre monitor (doesn't tell you which one)
When initially playing with iDrive I saw the 'Flat Tyre Monitor' screen showing a picture of a transparent car with four green tyres. I assumed the point of this was that it would tell you which tyre had a puncture, but I think that was a wrong assumption now.
So, I'm driving up the A24 this evening... bong! Some message appears about tyre pressure loss and the iDrive switches to the transparent car picture, now with all four tyres showing orange! Why have this fancy graphic showing each tyre coloured in individually if it's not going to tell you which tyre is stuffed? Anyway, pulled into a lay-by, checked the tyres for anything unusual - offside front felt ever so slightly warmer than the others, otherwise nothing. When I got home had another look and can see what could be a small stone stuck in the centre of the offside front. Prodded it with a screwdriver and it wasn't going to budge so I left it. On the downside, can't find my tyre pressure gauge to confirm. On the upside, took out tyre insurance so shall leave the car at the dealer tomorrow morning and ask them to sort it
Life is a state of mind |
11-08-2012, 02:35 AM | #2 |
Rep 4,939
Drives: 340i MPPSK
Two rears and n/side front all 2.2 bar, front o/side 1.8 bar - does that sound a bit high to be a puncture?
LobB5109.00 |
11-08-2012, 02:50 AM | #3 |
Rep 1,197
Doesn't immediately make me think of puncture. Be a very slow one if it were
Get it back up to pressure and check it again after 24/48hrs I can't remember if you had tyres included with your package Rob?
ZMS | ZNP | ZVI | 2VF | 2VL | 3AG | 494 | 6NS | 8TH |
LobB5109.00 |
11-08-2012, 03:49 AM | #4 |
Rep 4,939
Drives: 340i MPPSK
Yep, got the tyre package. Three punctures in two and a half years on my last car, so thought it wise.
LobB5109.00 |
11-08-2012, 03:59 AM | #5 |
Rep 1,197
Good man. Less of an issue then if you do have a puncture
11-08-2012, 05:50 AM | #6 |
1993
Rep 9,500
RE-SET the system after getting all tyre pressures correct, then you should be OK, the system thats on the car measures the "inflation difference" between the tyres.
2023 LCI M5 Marina Bay Blue/ Smoked White Leather, the very last of the F90 M5. |
LobB5109.00 |
11-08-2012, 12:22 PM | #7 |
Rep 4,939
Drives: 340i MPPSK
Re-inflated and re-set after which the front offside lost 0.2 bar so dealer sorting it under the insurance. Incidentally, they seemed to think that in certain circumstances(?) the iDrive Flat Tyre Monitor will indicate which tyre has the problem.
LobB5109.00 |
11-08-2012, 01:02 PM | #9 |
Rep 4,939
Drives: 340i MPPSK
Think I've seen on the US forum something about Flat Tyre Monitor (and tyres with rubber valve stems) vs. TPMS (and tyres with metal valve stems). Regards the F30/31 not sure if TPMS is a US-only thing or what?
11-08-2012, 02:11 PM | #10 | |
Rep 9,708
I am thinking we only get the ABS speed differential system in the UK as standard.....I may be wrong though. |
LobB5109.00 |
11-09-2012, 04:17 AM | #11 | |
1993
Rep 9,500
I tested the system after and let some air out of a front wheel and it showed that wheel was at fault, so the TPM needs looking at.
LobB5109.00 |
11-09-2012, 05:24 AM | #12 |
Rep 4,939
Drives: 340i MPPSK
Damn, didn't see your post in time - already got the car back, complete with new front tyre (sharp stone had managed to pierce it).
I will try letting down one tyre over the weekend and see if the Flat Tyre Monitor picks up which one. The system definitely showed me four orange tyres on Wednesday night though.
LobB5109.00 |
11-09-2012, 06:25 AM | #13 | |
1993
Rep 9,500
The Yanks would like our system it's simpler and should in most cases show which wheel is at fault.
LobB5109.00 |
11-09-2012, 06:42 AM | #14 |
1993
Rep 9,500
Correct.
11-09-2012, 07:08 AM | #15 |
Rep 15,858
The 'full fat' Tyre Pressure Monitor, which monitors the individual pressures and gives the read out, is an option in the 5-series. Option SO2VB, at £255
Can't see that option on the 3-series, so doesn't look as if anyopne can have a wheel specific readout. Standard TPWS is only a puncture warning system, nothing more. HighlandPete |
LobB5109.00 |
11-09-2012, 08:40 AM | #16 | |
1993
Rep 9,500
I would assume that it does just advise a puncture and you have to search for the culprit, cheap sh*t system I you ask me.
LobB5109.00 |
11-09-2012, 10:40 AM | #17 |
Rep 106
On my 520d which has the basic system it tells you which tyre.
Please don't tell me that the 3 series has an even more basic system. would have thought they were the same the graphic is identical |
11-09-2012, 10:45 AM | #18 |
1993
Rep 9,500
I am going to test the system sometime soon.
11-10-2012, 10:08 AM | #19 |
1993
Rep 9,500
Tested it today, needed to let 30% pressure out and it showed The correct wheel , so the picture comes up with the correct wheel that is the problem,
11-10-2012, 10:30 AM | #20 |
Rep 9,708
11-10-2012, 10:33 AM | #21 | |
Rep 15,858
Have been reading the 5-series manual and it does indicate the standard TPWS will show which wheel is at fault. If all wheels show the yellow/amber warning, TPWS is either not set, or there are issues with more than one wheel, possibly while resetting the system. As I stated in the earlier post, there is the advanced TPM system for the 5-series, which does show the actual real time tyre pressures. HighlandPete |
11-10-2012, 10:36 AM | #22 | |
Rep 9,708
