11-30-2013, 04:36 PM | #5150 |
Rep 3
Well it seems that coding my car is a NoGo for me (at least for now).
Thanks to Shawnsheridan, Dataready & Utenigma for their help, links & info. I downloaded, Install & setup E-Sys no problem; downloaded ALL PSdZData files overnight no problem; BUT unfortunately when I was unzipping part#10 (out of 44) of the PSdZData my computer hard drive ran out of space I only had 100GB free At least I didn't have time to buy the Token or Cable! |
11-30-2013, 05:43 PM | #5151 | |
Rep 3,227
11-30-2013, 07:08 PM | #5152 |
Rep 1,980
Drives: 2020 G20 320i M Sport
Has anyone encountered this problem while FDL coding HU_NBT?
I VO coded my retrofitted HU_NBT today so that it would get my vehicle configuration, language and radio frequencies and it worked but as soon as I FDL code something else from HU_NBT like Startup Emblem, everything reverts back to its previous VO but everything I FDL coded will remain. After the FDL code, it changed my chassis type back to F31 and the default language to German. I thought it was because my HU_NBT is retrofitted but today, VO coded someone's 2014 335i with factory NBT and when I FDL code something, the 6NS features are gone but the features coded via FDL are there. |
11-30-2013, 08:43 PM | #5153 |
Rep 41,044
PM sent.
11-30-2013, 08:45 PM | #5154 | |
Rep 41,044
11-30-2013, 08:52 PM | #5155 | |
Rep 41,044
11-30-2013, 09:14 PM | #5156 | |
Rep 1,980
I have a feeling it is because I unchecked Update VCM after TAL execution. I'll check that off again and see what happens. |
11-30-2013, 09:20 PM | #5157 | |
Rep 41,044
Did you write the modified VO to the car, or does car have original VO in it?
11-30-2013, 09:34 PM | #5158 |
Rep 1,980
It's a modified VO with 6VA removed, 6NH changed to 6NK and build date changed from 0312 to 1112. The strange part is, I don't know where HU_NBT is getting its original VO coding from because as soon as I FDL code something, my PDC shows a F31 and all the menus are in German again. It seems like the NBT has a way to revert back the VO from its previous car.
11-30-2013, 09:35 PM | #5159 | |
Rep 41,044
11-30-2013, 09:36 PM | #5160 |
Rep 1,980
12-01-2013, 12:28 PM | #5161 |
Rep 100
is there a very big difference between the older ESYS programs and the newest? I am having a difficult time following the how to's because I don't even see what they are talking about like the reading the VCM, The VCM is nowhere on the coding screen.
Thanks in advance! |
12-01-2013, 12:35 PM | #5162 | |
Rep 41,044
12-01-2013, 12:39 PM | #5163 | |
Rep 100
Now when I do that and am doing the CAFD backup I have an issue where it says that it was not found. Is that a connection problem or user error? everything works fine up to that. |
12-01-2013, 12:43 PM | #5164 | |
Rep 41,044
What is the exact error you are getting? What PSdZData version are you using, and what is your I-Step Current? http://www.f30post.com/forums/showpo...postcount=1403
12-01-2013, 12:54 PM | #5166 |
Rep 41,044
And the exact Read error is what?
12-01-2013, 12:55 PM | #5167 |
Rep 100
Here is the error that I am getting.
Transaktions-Report: Aktion: Codierdaten lesen ACSM [1] [F078520] readCPS o.k. cafd_00000909-004_002_024 Fehler: File for "cafd_00000909-004_002_024" not found! [C012] ACSM [1] [F078520] readCPS o.k. cafd_0000090a-004_003_011 Fehler: File for "cafd_0000090a-004_003_011" not found! [C012] ACSM [1] [F078520] readCPS o.k. cafd_0000090b-004_003_009 Fehler: File for "cafd_0000090b-004_003_009" not found! [C012] |
12-01-2013, 12:58 PM | #5168 | |
Rep 41,044
12-01-2013, 01:03 PM | #5170 | |
Rep 41,044
And do you have this folder on hard Drive: C:\ESysData\psdzdata
