BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > F30/F32/F33 Classifieds (For Sale / Trade / Wanted) > Members Classifieds > Suspension / Brakes / Chassis / Spacers > BMW 335xi M-Sport Brakes
Studio RSR
      07-10-2017, 09:29 AM   #23
peterparker
Drives: e90
2009 BMW 335i  [0.00]
Originally Posted by gling View Post
Hi there,
Yes the brakes are still available but these are the stock M-Sport brakes (4 pot fronts and 1 pot rears) that come unpainted on the car. These are not the colored/painted M-Performance units if those are the ones you are looking for. Let me know if you are still interested.
Best regards,
Gerald.
This sounds like the factory 335i brakes. Unpainted calipers (4 pot) with the 340mm fronts. I think the factory optioned "M brake kit" ( or whatever they call it) is with the blue calipers front and rear, 370mm rotor up front.
GLWS!
      08-20-2017, 11:11 AM   #24
gling
Drives: X3 M35i + M335xi + R35 GTR
Bump. Can deliver anywhere along the Boston - Philadelphia route if needed.
      08-29-2017, 01:56 PM   #25
gling
Bump!
sgovind77.50
      09-08-2017, 04:31 PM   #26
gling
Bump with lowered price!
      10-01-2017, 11:09 AM   #27
gling
Bump!
      10-29-2017, 09:15 PM   #28
disgruntledcow
disgruntledcow's Avatar
Drives: 2014 335i Msport Xdrive 6spd
GLWS!
Correct, only Blue M sport brakes are 370mm.
      04-29-2018, 08:43 AM   #29
ProAktion
Drives: 2016 750i
2008 BMW / 335i  [0.00]
You still holdin these? I am interested.
      05-21-2018, 12:57 PM   #30
gling
Bump!
      06-18-2018, 08:55 AM   #31
gling
Bump!
      06-18-2018, 01:00 PM   #32
AMSWagon
Drives: G63
Are these the ones stamp Brembo?
      06-20-2018, 04:46 PM   #33
hevykevy420
Drives: '12 328i
Prefer to sell as a set at the moment.
Not sure but possibly. Maybe someone else on the forums can verify but I am not sure personally.
Rears will def not fit 328i models. Not sure if any xi owners have tried to confirm either....
http://f30.bimmerpost.com/forums/sho....php?t=1004809
2016 528i Msport/Premium/Drivers Assist II/ACC/Cold Weather/Harmon/Pwr trunk
2012 Kawasaki ZX10R ABS
1978 Honda CB750k,
1977 Yamaha XT500
1975 BMW R90/6 & 1969 R69S
      06-21-2018, 09:58 AM   #34
gling
No, these are the stock units. 4 pot calipers up front, and 1 pot in the back.
      06-21-2018, 12:01 PM   #35
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
The 4 piston fronts should be Brembo, rear 1 pistons are Bosch
      07-07-2018, 04:15 AM   #36
decre83
Drives: bmw 125i coupe 2012
how much just for front calipers?
      07-31-2018, 12:34 PM   #37
gling
Bump!
      08-01-2018, 07:51 AM   #38
Tribalpinoy911
Tribalpinoy911's Avatar
Drives: F34
Wow thanks for the info, i was about to purchase these for my xdrive. Would of been disappointed if they wouldn't fit. I thought it was a simple bolt on.
      08-01-2018, 01:11 PM   #39
gling
Just went through the entire thread and post #36 and #44 state that the rear calipers will work with XDrive models since they use a larger diameter e-brake setup.
https://f30.bimmerpost.com/forums/sh...7&postcount=36
https://f30.bimmerpost.com/forums/sh...7&postcount=44
      08-01-2018, 02:51 PM   #40
hevykevy420
Drives: '12 328i
My experience in the post I authored was strictly limited to RWD. When I researched all the part numbers back then it looked like xi models shared the rear hub/ebrake parts with the 335. As gling pointed out, it looks like a few xi folks confirmed my suspicion with actual parts, and the 4 cyl xi models can swap rear hub/ebrake parts with 335 at least according to the posts gling noted. If that is true, Tribalpinoy, you should have a direct bolt on with an xi model. Or xdrive, or whatever bmw is calling AWD these days!
and if you want the painted caliper look that the bmw option provides, take a look at the photos I provided, those calipers are simply the grey unpainted 335 calipers with high temp primer and paint out of a rattle can, bake in the oven and use some brembo vinyl labels. You can have them powdercoated if you want but the high temp paint if prepped properly holds up great as long as you prepped for paint properly and don't drizzle brake fluid all over the calipers...
1978 Honda CB750k,
1977 Yamaha XT500
      08-02-2018, 07:37 AM   #41
gling
For what it's worth, thanks for all your research and comments on this topic from your other post; it is people like you that make it so much easier for folks to tinker with their cars.
Gerald.
      08-21-2018, 09:11 PM   #42
Overshotgolem
Overshotgolem's Avatar
Drives: F30 328! 2013
What’s the price ?
      10-23-2018, 11:59 AM   #43
gling
Originally Posted by Overshotgolem View Post
What’s the price ?
$650 and bump!
      11-29-2018, 09:49 AM   #44
whoismorggan
Bimmer Nut + Software Dev
whoismorggan's Avatar
Drives: 2018 Audi S3 IE Stage 1
Interested in the front set only. Let me know!
