05-20-2013, 10:45 AM | #3675 |
Rep 40,785
You can't. Dealer Program will wipe all FDL Coding.
05-20-2013, 11:44 AM | #3676 |
Rep 131
Garage List 2018 BMW i3 Rex [0.00]
2016 BMW F20 M135i ... [0.00] 1999 BMW Z3/E36 - 1.9i [0.00] 2004 BMW Z4/E85 - 2.5i [5.00] |
I succesfull coded some options, i found also camera_watchdog and startup_emblem, in the lastone you can choose+-10 options... someone now what this is ?
05-21-2013, 03:06 AM | #3677 |
Rep 7
Okay, I was doing great until I messed something up tonight.
A couple weeks ago I coded several options (auto-fold, no disclaimer, cameras in motion, etc.) and everything worked great. Tonight I went through and edited a few more options in HU_CIC and FEM_BODY. It was late, I was tired, and instead of clicking the "Code FDL" button in the right pane, I right-clicked the CAFD and clicked "Code". Everything looked liked it worked fine until I finished FEM_BODY and got active blindspot and drivetrain malfunction warnings. Now, besides the malfunction warnings and the wiping out of my previously coded settings, Comfort Access doesn't appear to be working to lock/unlock the car. Now, I see CAFD_FFFFFFFF_255_255_255 under FEM_BODY and it won't let me code it again. I made a backup of all the CAFD files before I started any programming, but I have no idea how to get it fixed. Please tell me there's some magic reset button I'm missing and I won't need to take my car in to the dealership to get reprogrammed. Thanks! |
05-21-2013, 10:04 AM | #3678 | |
Rep 40,785
Are you coding your car with the engine off, or did you experience in some other way a Power Interruption? It is imperative the car be maintained at proper voltage while coding, else this happens. To fix this: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on FEM_BODY => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level => Select OK => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE.
05-21-2013, 10:51 AM | #3679 | |
Rep 7
I've been programming with the ignition on, but engine off (which I thought was what the PDF instructions said to do). I have since read that you program with the engine on, and I will be sure to do the same. |
05-21-2013, 11:04 AM | #3680 | |
Rep 40,785
05-24-2013, 11:41 AM | #3681 | ||
Rep 67
Hi Demge. Tried these couple times and coded successfully. Somehow the 4th button short press is still not working. Can not get pathway lighting to work on remote. Btw, I mainly need and use this feature when I go coffee shops. Drivers here in my city are mostly morons. They like to park close and ding your door or touch parallel park. Thus if I see one is parking next to my car, I like to turn on the pathway light to alert them that someone is watching. |
05-24-2013, 01:20 PM | #3682 |
Rep 145
Drives: F30 320ed
We only have three buttons here in the UK by the way. So is it only the short function that doesn't work or follow me home lights at all on the 4th button.?
Also try enabling this: CAF [FEM_01] 3060 LceMaster, 1C FOLLOWMEHOME_VIA_FFB nicht aktiv > aktiv Last edited by demge01; 05-24-2013 at 03:39 PM.. |
05-24-2013, 02:17 PM | #3683 | |
Rep 1
Other than 2 message boards, I have been unable to find any other link or reference to this supposed promo. |
05-24-2013, 03:56 PM | #3684 | |
Rep 1,892
http://www.shopbmwusa.com/PRODUCT/38...cessories.aspx |
05-24-2013, 04:30 PM | #3685 | |
Rep 40,785
Anyway, Frogman has provided you with the official BMW Link for this promotion.
05-25-2013, 12:08 AM | #3687 |
Rep 131
Is here somone that knows what this code does ?
camera_watchdog and startup_emblem, in the lastone you can choose+-10 options... Thx |
05-25-2013, 01:08 AM | #3688 |
Rep 1,892
05-25-2013, 07:10 AM | #3689 | |
Rep 171
05-25-2013, 11:31 PM | #3690 |
Rep 131
Thanks for the info, i will try to change today and see what happens
05-26-2013, 01:15 AM | #3691 |
Rep 131
Hi all,
I just changed this: HU_BNT 3001 STARTUP_EMBLEM > variant_01, this gives me now the M startup emblem in the nav display. Have one question do, how to make the startup/welcome screen manual visable ? I mean when i open the car it shows the Mperformance in the dash, i push the start button and the nav display starts right up to for example radio or nav, i dont see the welcome screen because it starts right up. I only saw the M logo after coding and the displays reseted. So how to turn on or off the display that i can see the startup/welcome screen ? Thx |
05-26-2013, 01:39 AM | #3692 | |
Rep 1,309
Drives: YMB M3
Garage List 2016 BMW X6M [0.00]
2018 BMW M3 [0.00] 2015 BMW X4 35i [0.00] 2015 BMW M4 (SOLD) [0.00] 2012 BMW 328i SL(SOLD) [0.00] 2008 BMW 328i (SOLD) [0.00] 2007 C230 Komp (SOLD) [0.00] 1999 BMW 328i (SOLD) [0.00] |
05-26-2013, 09:16 AM | #3693 | ||
Rep 144
05-26-2013, 10:45 AM | #3695 |
Rep 383
I was looking to disable fogs on when turning... I want to make sure I didn't disable my adaptive headlights. I would appreciate it if someone posted the correct items to disable for fogs and which items should be enabled for adaptive headlights. When disabling the fogs, my car said "Adaptive headlight malfunction" for a few seconds when coding. Just want to make sure I didn't disable those too. THANK YOU!
05-26-2013, 12:05 PM | #3696 | |
Rep 40,785
C_CLC_ENA = F030disable - Switch to disable CLC (cornering fog light)
