BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Newbie help
      06-12-2013, 02:41 PM   #1
Mr NSB
Drives: 420d M-Sport
Newbie help
I have had a go at coding for the first time and was not successful so would like a little help.
After reading about coding and looking at the cheat sheets I thought I would like give it a try so I found the E-Sys download and installed it as per the coding sticky.
I am using E-Sys 3.18.4 with PSdZ files 48.3. My F30 is a UK spec 320d Sport, with a July 12 build date.
For my first attempt I picked on having a go at setting my door handle LED's to come on when reversing (backing up) and hit on an error message right at the end of the Coding FDL process. I was following the 'E-Sys Getting Started Coding Part 1' pdf from the sticky thread.
This is the error message:
Transaktions-Report: Aktion: FDL Codieren
FEM_BODY [40]
cdDeploy ProcessedWithError
cafd_00000794-004_124_042 Not Executable
I also tried to set the digital speed display and ended up with a similar error message so I gave up at this point.
BKOMBI [60]
cafd_00000760-006_000_019 Not Executable
After the digital speed code attempt I had to reset the time and date and the mpg/ave speed display had reset also.
What am I doing wrong?
      06-12-2013, 04:25 PM   #2
Frogman
Drives: 2012 F30 328i
For the F30, the 48.3 psdzdata requires a new token as the Code Away one that comes with 3.18.4 is not valid with that version or newer.
If your car is old enough, grab a copy of psdzata 48.2 and see if you can code with that as the Code Away token will work on that dataset.
If you get an error like CAFD not found/missing, then your car has newer software on it and you will have to go to 48.3, or even later (49.4 is out now).
To use 48.3 or newer, you will need E-Sys 3.22.5, the newer psdzdata, and you will need to purchase a token.
Send a PM to shawnsheridan and ask nicely for instructions and links.
      06-12-2013, 05:18 PM   #3
Mr NSB
Thank you for the reply Frogman.
I will have look for 48.2 and try this first. You wouldn't happen to have a link would you, cheeky of me to ask I know
      06-12-2013, 05:45 PM   #4
Frogman
Sorry, I don't have the links. shawn is the master of the links here for getting psdzdata. Send him a PM requesting the 48.2 links and he's very good about responding.
      06-13-2013, 12:59 AM   #5
Mr NSB
I have PM'd Shawn and had an instant reply, what a top man
Thanks Frogman
      06-13-2013, 02:46 AM   #6
rich1068
has left the building
Drives: F30 330d M Sport
If you need any UK specific help you can obviously ask over in the UK section as well as here. I've just gone through the coding initiation and it is a little confusing to start with and then the penny drops.
      06-13-2013, 03:05 AM   #7
Mr NSB
The UK section is the first place I go when I log in.
I thought I would post in the coding section as you never know it might be useful for another member in the future and I thought the audience might be larger.
If I was looking for specific UK help I will be asking in the UK section.
Rich it was the post's between yourself and RichardM that started me looking at trying coding in the first place.
      06-15-2013, 04:30 AM   #8
Mr NSB
**Update**
I have successfully coded with PSDZdata 48.2, thank you Frogman for the heads up and Shawn for the link
So far I have LED's lighting up in the door handles while reversing.
ASS to last setting.
Digital speedo.
DRL iDrive option to turn off.
Left/right Fog lamps illuminating while turning with auto lights mode.
      06-15-2013, 12:53 PM   #9
rich1068
Don't they do that already? I'd never paid attention to be honest. Just assumed they did. Like VWs.
      06-15-2013, 01:54 PM   #10
Mr NSB
Mine didn't and it is one of the things I missed from my previous car which had the cornering lights built in to the headlamps.
