11-08-2016, 07:37 AM | #23 |
Rep 1,380
Hi guys,
The sale of these is now on hold as I have a potential buyer. If anything changes at the weekend I'll keep you all informed.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) Last edited by fortythirtyfive; 11-10-2016 at 05:13 AM.. |
11-09-2016, 04:09 PM | #24 | |
SEAL TEAM SIX
123
Rep 498
"There's an over lip on one, if it really bothers you then you might want to dremel it down, but after talking to BMW about it; it turned out to be the valve that was loose and not related to the lip (they tightened it up for me and solved that issue). Ironically the worse of the problems happen to all be on one wheel. You can see the outer edge that hasn't been shaved off with a dremel yet (this also is the area that needs some extra lacquer spraying on as you can see it's been missed)."
DON'T MAKE ME ANGRY!
GO1 LCI PHEV 30e. M Sport plus Pack, Tech Plus Pack, Comfort Pack, Pano sun Roof, Sensatec dash with Blue stitching, HUD, Galvanic controls. Last edited by JOE YOUNG; 11-10-2016 at 05:28 PM.. |
11-10-2016, 05:12 AM | #25 | |
Rep 1,380
The second paragraph is me mentioning that the worse of problems all fall on one of the wheels overall. The area on that wheel that I just mentioned above is also an area that is in need of some lacquer.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
