05-23-2016, 12:19 PM | #1 |
Rep 218
Coolant Resevoir in B58 340i Engine
Hey everyone.
I've been getting an intermittent "Add Coolant" message, so I went to add some this morning and, lo and behold, I couldn't figure out which spout to pour it into. Tried looking at the manual, but the diagram shows the four cylinder model which isn't helpful and searches didn't yield any results other than both spouts may, in fact, be for coolant (one for the intercooler/DME and the other for engine cooling). Before I go dousing my engine in coolant, thought I'd try getting the two cents of those more knowledgeable than me. So which is it, the green circle or the red? Thanks for the help! |
05-23-2016, 01:38 PM | #2 | |
Rep 3,943
05-23-2016, 02:19 PM | #3 |
Rep 218
Thanks so much Polo! That was my hunch based on the fact that it's the more prominent one. Any idea what the green is? Not sure how to access the ISTA+ myself.
I just noticed you actually included the pdf, thanks so much for that. Although now I'm scared as it says that "water can filling is not permitted for this engine" and that it should be filled with a vacuum filler. Not sure if that includes topping off, but geez, have these cars gotten so advanced that I can't even add coolant myself? Last edited by alistairk; 05-23-2016 at 04:38 PM.. |
05-24-2016, 04:17 AM | #4 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
@alistairk
I had the same issue during the first week of my purchase. I took it to the dealership and they added Coolant. According to my Service Advisor, B58 Engines apparently have 2 Reservoirs. 1 of the reservoirs wasn't filled up at all at the Factory. Take it to the Dealership and they will take care of it asap. |
05-25-2016, 10:32 AM | #5 |
Rep 1,056
I was checking my coolant level and also confused upon opening the hood.
Obviously I didn't read the manual. just bought a bottle of distilled water and top off the main reservoir. weird it doesn't come with correct level from factory
05-30-2016, 01:22 AM | #6 |
2JZ-GTE
3005
Rep 3,986
i smell coolant in my 340 lately... probably not a good sign.
06-14-2016, 11:30 AM | #7 |
Rep 1,056
I topped it off before a 1100 miles trip. After the trip I have to top it of again (with distilled water).
I topped it off to the max line and after 1100 miles it half way to the min. I don't suspect a coolant leak in a brand new 340i. Neither I see any liquids on the floor of driveway. Where did the coolant go? I bought a gallon of the OEM coolant for future in case.
06-14-2016, 01:36 PM | #8 | |
Rep 703
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
08-03-2016, 12:41 AM | #9 |
Rep 3,622
This happened to me too. A faulty coolant cap can cause it to evaporate. It happened on the old e36 325is my family had. Replaced cap, never again an issue.
I'm watching mine carefully to see if there's further issue but I think the dealer was successful in topping it of and keeping it in there
BMW CCA Member #516012
TiffanyatSouthMotors12.50 |
08-03-2016, 10:08 AM | #11 | |
Rep 3,622
08-03-2016, 10:20 AM | #12 |
Rep 140
08-03-2016, 10:22 AM | #13 |
Rep 3,622
I watched the guy top it off at the dealer in mine. Just let the car cool completely. I mean completely! Then top it off. Pretty sinple. Just use eyeball test. A little coolant overflow dripping to the ground is all good
08-03-2016, 10:24 AM | #14 | |
Rep 140
Going to pick up BMW coolant after work Thanks again! |
08-03-2016, 10:42 AM | #15 | ||
Rep 3,622
08-03-2016, 11:06 AM | #16 |
Rep 140
I've thought about this but timing just won't work out.
Since the service dept closes at 5:30p, this gives me about 30 minutes to let the car cool down and refill coolant if I go after work. Timing seems really tight. Plus, I don't want to leave my car overnight just to refill coolant. Interestingly enough, I got my car checked out and fully serviced last week at BMW. I can't believe they didn't check coolant! But that is why I wanted to just buy it and do it myself. Thanks for the suggestion though! |
08-03-2016, 11:48 AM | #18 | |
Rep 218
08-03-2016, 11:51 AM | #19 |
Rep 140
08-09-2016, 02:18 PM | #20 |
Rep 1,240
Drives: 2016 BMW 340i
It is not pre-mixed.
Has to be mixed with water, 1:1.
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals |
09-02-2016, 09:44 AM | #22 |
Rep 647
Hey guys -
So as of this morning, I'm low too. I don't feel like driving to the dealership to get "BMW Coolant" so what's the Advanced Auto Parts equivalent? Is it just generic engine coolant that you dilute 50:50 with water? Or is it a BMW magical blend of herbs and spices?
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i |
