04-26-2013, 12:32 PM | #1 |
Rep 1,185
Warranty still honored if you do your own oil changes/repairs?
If something happened, like your engine blew up, and they found out you did your own oil change, could they say it's your fault?
If you bought an oil filter from them, would that be enough evidence that you did your own oil change? |
04-26-2013, 12:36 PM | #2 |
Rep 467
They can not deny warranty work unless there is a direct correlation and causation from the work you performed and the resulting damage.
2011 335is Black/Oyster. 1 of 46 without moonroof (total of all years): JB4 E50 tune, gone
2013 335i M Sport JB4: Estoril Blue gone 2018 M4 ZCP: current 2023 X3M Comp: current |
04-26-2013, 12:58 PM | #3 | |
Rep 6,989
The only way doing your own oil change would cause a problem is if you didn't use the correct oil or filter element or failed to secure the drain plug or filter housing. That'd be the same for any car. I've never heard of a BMW engine "blowing up" (whatever that implies) unless it was being severely abused - they investigate thoroughly, and look for root cause of the failure. If you need to go to somewhere other than a dealer for an oil change, just make sure you get a receipt and keep it in your owner's manual as proof.
04-26-2013, 01:09 PM | #4 | |
Rep 1,185
Blowing up was obviously a hyperbole, but if you lose oil due to a drain plug not being tightened properly then it could seize. Last edited by bcl0328; 04-26-2013 at 01:50 PM.. |
04-26-2013, 02:21 PM | #5 | |
Rep 6,989
04-26-2013, 02:26 PM | #6 | |
Rep 1,185
04-26-2013, 02:44 PM | #7 | |
Rep 821
04-26-2013, 03:04 PM | #8 |
Rep 1,975
Changed my oil w/ Mobil 1 and BMW filter for $40.. And had fun doing it
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
04-26-2013, 03:04 PM | #9 | |
Rep 226
04-26-2013, 03:20 PM | #10 |
Rep 271
04-26-2013, 03:53 PM | #11 |
Rep 4,323
i get oil changes at my dealer for $60...the local market has driven down prices, so they're always offering coupons.
04-26-2013, 04:16 PM | #12 |
Rep 6,989
All that aside...documenting in-between oil changes is not a bad idea, no matter how you do them. Also - if you don't put a lot of mileage on your car per year like me, the computer will recommend an annual change. I won't come close to 15K miles between now and next March, although I'll probably hit 7.5K about then, so I'm hoping to get my 1st oil service as part of maintenance.
04-26-2013, 04:18 PM | #13 |
Rep 6,989
Omigosh - how can you even use the word "Walmart" when talking about your BMW?
04-26-2013, 04:57 PM | #14 |
Rep 1,185
04-26-2013, 04:59 PM | #15 |
Rep 1,185
04-26-2013, 07:20 PM | #16 |
Rep 6,989
True enough, but I was just thinking of all those "Wal-Mart Customers" picture collections I've seen. Makes you want to park across the street and walk.
04-26-2013, 08:04 PM | #17 |
Rep 1,185
04-26-2013, 09:56 PM | #18 |
Rep 4,553
Refer to Magnuson-Moss Warranty Act. A federal statute that all auto manufacturers must live by.
Basically, BMW has the burden to prove that the 3rd party work was faulty. http://en.wikipedia.org/wiki/Magnuso...s_Warranty_Act
2023 840GC | 2021 740i | 2019 X3
04-27-2013, 01:22 AM | #19 | |
Rep 7,047
Mag-Moss sought to eliminate "tie-in" sales to maintain warranty. That means that a manufacturer can not deny warranty coverage if you did the maintenance work yourself or had an independent shop do it, as long as the parts used met the manufacturers specs, and the customer can show receipts for the parts used. For example, the manufacture can't force or make a customer buy a specific brand oil in order to maintain warranty. That also goes for the work involved. Thus, a customer can change their own oil as long as they use oil filters and oil that meets the manufacturer specs, and as long as they can show that the maintenance was preformed warranty can not be denied. But, there is an exception in the law. The manufacturer CAN require specific brand oil and filters IF the manufacturer provides the parts and labor free of charge. BMW does provide and perform all the required maintenance free of additional charge. This means that BMW could deny a warranty claim if the customer doesn't use BMW specific oil and filters, not just parts that meet manufacturer specs. Of course, it is not likely that BMW would do that to a customer, but according to the law, BMW would be within the law if they denied warranty to a customer who used non BMW specific oil and filters. It's an odd quirk, but it's in there. |
04-27-2013, 08:24 AM | #20 | |
Rep 4,553
Regarding the Act, I'm not sure of this provision you refer to, but what was the intent of Congress? Intent goes a long way. One can argue that BMW does not provide maintenance "free". The cost is built into the MSRP of the vehicle.
04-27-2013, 11:36 AM | #21 | |
Rep 1,975
And I also keep and file my oil and filter receipts just in case. |
04-27-2013, 02:05 PM | #22 | |
Rep 1,185
