BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > 2015 335 , Is my engine toast ?
      03-06-2024, 12:20 PM   #1
Skrrtt335
Drives: 2015 335
I drove the car for about 1 hour straight car was running fine , i then stopped and to get food . when i went back to start the car it only cranked(almost turning on) but did not start. got the car towed home & had 2 mechanics come look at it . the first mechanic tested fuel pumps and they both seem to be working . Checked all fuses too . He did a spark test to the coils and they were not getting spark he said it might be the crankshaft sensor . BOTH MECHANICS SAID NO CODES SHOW UP , i also checked codes with bm3 and only code i get is
- 21a023 combustion engine : false start or engine stopped without driver influence
2nd mechanic said there was spark and did compression test and all cylinders came back to 60PSI and that i need a new engine
i'm confused from both answers and my questions are would no spark cause engine to have low compression ? The car was driving fine before it wouldn't start . where else should i look or what other tests should i run before getting into buying a new motor .
      03-06-2024, 12:34 PM   #2
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
I dont see how the engine would be toast if it ran when parked. My guess based on the limited information (not starting and low compression assuming thats true) is a valve/tronic issue
      03-06-2024, 12:36 PM   #3
Slumped335
Drives: BMW 335i
  [0.00]
Sorry i don’t have a direct answer. Mainly just questions.
-What is ur current mileage?
-What Maintenance have you done?
-When was the last time you changed Spark Plugs / Coils?
-Did you take it to a dealer or an indie shop?
Anymore info would help narrow down things.
Hopefully someone will be able to give you an answer.
      03-06-2024, 01:29 PM   #4
Skrrtt335
Drives: 2015 335
yeah the i drove the car an hour and a half with no issues and soon as i turned it off to walk in the store for 10 mins came back out and it just cranked . thats true tho 2nd mechanic told me the same
      03-06-2024, 01:38 PM   #5
Skrrtt335
Drives: 2015 335
Current miles : 134k bought at 75k was told they did maintenace on the car ( water pump ) i changed spark plugs & coils when i got the car , just changed spark plugs today to see if it would change anything . waiting on coils to come in . car also has new battery i put in after the day it wouldnt turn back on. mechanic 1 came to me since he works as a mechanic for autozone off the books & mechanic 2 was the indie shop . oil changes every 5k miles
car is also on bm3 stage 2 tune fbo running 93
had some issues of the engine stalling out like 3 times in the past 3 years while cruising on the highway bout 80mph sometimes coming back on as im still on the gas pedal ( seemed like fuel pump but they both seem fine ) car always started back up , i can post bm3 logs of fuel pumps psi i have while cranking the car if that helps in any way . car takes a while to turn on sometimes in cold weather and has small valve cover leak
https://youtube.com/shorts/VxVy4_sO0UQ?feature=share
video of how it sounds when cranking
      03-07-2024, 07:58 PM   #6
BeastMode335i
Maximus Decimus Meridius
BeastMode335i's Avatar
Drives: F30 335i
Bro weirdest shit ever, my F30 just did this same exact thing almost yesterday. I pulled in to get food and as I was driving away it turned off. I pulled codes and had 21A023, and I cleared it with MHD. Car started up and drove home about 4 miles w/o issue after that..... Strange...
F30 335i
Melbourne Red Metallic
M-Sport Package
      03-14-2024, 11:38 AM   #7
Slumped335
Drives: BMW 335i
  [0.00]
For what it’s worth i don’t think your engine is toast. It sounds potentially electrical? Cam Sensor losing signal or something.
IMO it might be worth taking it over to a BMW dealer and seeing what they say. $250~ in Diagnostics is way better peace of mind than a autozone mechanic and a indie mechanic.
Sorry i’m not more help. I personally take my car to a indie shop for all my work.
Good luck man!
      03-14-2024, 07:06 PM   #8
Skrrtt335
Drives: 2015 335
thanks for all the advice guys , i have it at a bmw specialist rn he thinks its valvetronic issue . He said hes taking the valvecover off tmr . i did get valvetronic motor code when i checked for codes when car didnt start but i cleared it and never came back . He also said car was showing low compression on all cylinders . could that be bc of valvetronic stuck or not working ? car has spark / fuel .
      03-14-2024, 08:37 PM   #9
thejeremyman9
4364
If the valves are not opening/closed when they are supposed to, yes, that can cause low compression. Seems far more likely than a catastrophic failure on all cylinders at the same time when the car ran when parked...
      03-15-2024, 09:29 PM   #10
Skrrtt335
Drives: 2015 335
yeah the mechanic just got back to me & said my eccentric shaft had all my valves closed & the valvetronic motor blew . Going to replace the valve cover aswell cause i had a leak
      03-15-2024, 10:16 PM   #11
Slumped335
Drives: BMW 335i
  [0.00]
Well at least its not an entire engine. Glad to see that you at least came out on top. Good luck! Hopefully it wont be too much by the end.
