BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 8 Speed A/T
      01-17-2011, 12:31 PM   #1
exthree
The Fleet
exthree's Avatar
Drives: 2018 BMW 540i
8 Speed A/T
Will the new F30 be available with the new 8 speed automatic transmission?
      01-17-2011, 12:54 PM   #2
yakev724
yakev724's Avatar
231
Drives: 15 S3
too many gears unless the top speed is 250
      01-17-2011, 01:19 PM   #3
ToothDoc
Drives: 997.2 TTS, CLA 45 AMG
Why is it that everytime somebody mentions 8 speed, somebody always says '"too many gears"? FYI, just look at it like a close ratio 6 speed that most people use and 2 overdrive gears for fuel efficiency. You'll never see above 4 or 5th gear at a racetrack unless you are doing over 150 mph.
      01-17-2011, 04:33 PM   #4
Brey335i
Drives: e46 ///M3
I would venture a guess that the F30 will come with the 8 Speed ZF A/T and the 7 Speed DCT
      01-17-2011, 11:44 PM   #5
Want
YVR
Want's Avatar
Drives: A Monaco Blue
8 sounds like overkill...
mbmbmbmbmbmbmb
      01-18-2011, 12:41 AM   #6
pogodog
Drives: '08 335i
8 speed auto
I have a 335i with the auto 6 speed and have driven the 8 speed auto on the new 5 series (same engine). I like the smoothness & delivery of the 8 speed alot and it offers much better MPG (30 mpg hwy on the 535i that weighs 4100 lb.) I project that the new F30 335i with 8 speed auto @ approx. 3600 lbs will get at least 32/33 mpg Hwy.
      01-18-2011, 02:08 PM   #7
Want
YVR
Want's Avatar
doesnt e90 335 pretty much get 32-34mpg hwy with 6speed?
mbmbmbmbmbmbmb
      01-18-2011, 03:15 PM   #8
pogodog
Drives: '08 335i
mpg
A 2011 N55 engine in the 335i gets 28 mpg rating- 2011 535i gets 30 mpg rating (both by US EPA) both with auto transmissions
      01-18-2011, 09:26 PM   #9
eNineZero
eNineZero's Avatar
Drives: 2015 328i xDrive
I think the 8 speed is awesome and possibly the best automatic transmission. There's more to owning cars than racing them.
I found this very interesting and can't wait to get my ZF 8-speed f30.
      01-24-2011, 01:31 PM   #10
quality_sound
8 tracks of madness
Drives: Slowly
That was a pretty cool video.
      01-24-2011, 05:11 PM   #11
yakev724
yakev724's Avatar
231
Drives: 15 S3
+1
Interesting to think when/if there will be a big technological break in trans. function, seeing how the concept has stayed the same since the invention of the car.
      01-24-2011, 11:40 PM   #12
Elie335
ايلي ٣٣٥ هاهاها
Elie335's Avatar
St Pierre and Miquelon
88
Drives: Vorsteiner e92
I don't think the new 3 series will have 8 speed transmission....
      01-25-2011, 12:06 AM   #13
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
I'm pretty sure everything will get the 8 speed. No reason not to.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      01-25-2011, 12:46 AM   #14
Novator
Novator's Avatar
Drives: '04 E46 M3
2004 BMW M3  [8.00]
If this is true I could find myself liking this. I know it is not the same, but the IS-F has 8 gears and it is pretty quick.
      01-25-2011, 02:59 AM   #15
quality_sound
8 tracks of madness
Drives: Slowly
If Audi can use an 8-speed in the A4 and up and Lexus can use if in the IS models, there's no reason it can't be used effectively in the 3ers as well.
      01-25-2011, 12:22 PM   #16
M340i Pride
Drives: 2020 BMW M340i
looks like ZF is the number one in transmissions
      03-26-2011, 11:49 AM   #17
uberschnell
uberschnell's Avatar
Drives: Wide Body 1
ZF says the 8HP is six percent more *efficient than the outgoing sixer and nearly as efficient as a dual-clutch automated manual, which ZF also produces. However, the eight-speed is roughly 20 percent cheaper and retains the smooth, torque-converter starts to which U.S. buyers have become accustomed. Furthermore, the 8HP has a system to maintain hydraulic pressure even when the engine isn’t running and is therefore the first automatic that’s compatible with stop-start operation
http://www.caranddriver.com/features...sion-tech_dept
      04-01-2011, 05:54 PM   #18
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
I think an 8 speed in the 3 series is a no-brainer. Fuel economy standards are becoming very tough, and are stricter for small vehicles like the 3 series. If ZF is comparing fuel efficiency with a DCT, it is probably a dry clutch DCT. A dry clutch DCT is limited in the amount of torque it can handle. One is fitted to the VW GTI. Wet clutch DCT's as used by BMW don't have very good fuel economy due to pumping losses. Note that a 135i with DCT only gets an 18/25 EPA rating. However, I do like the way mine drives. I expect future use of the wet clutch DCT will be confined to low volume vehicles like M series or "is" models.
      04-02-2011, 12:41 AM   #19
TwinPowerF30
TwinPowerF30's Avatar
Drives: 2008 335i Coupe
Any talk about whether new 3 series will have DCT standard? Audi s4s have it standard.
      04-02-2011, 02:36 AM   #20
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Drive the F10 sport auto - then see what you think about 8 speed boxes.
      04-02-2011, 09:21 AM   #21
cpippolo
Drives: 2020 M2 Comp
I don't think this is right. Maybe they are changing for this coming year, but currently the DCT costs $1400 more than the manual on the S4. I recently text drove a manual S4 and it was OK, but didn't wow me. Haven't tried the DCT
      04-03-2011, 02:47 PM   #22
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
DCT is overkill (and expensive $$) for a standard feature. The new ZF 8HP transmission will be plenty good for most 3-series buyers.
