10-26-2017, 08:12 PM | #1 |
Rep 1,343
Winter Wheel Setup?
I am beginning to look for a new winter tire setup.
Looking for recommended black “salt resistant” high quality winter 18” rims? What would be the best width and offset for a near flush stance? I have the blue m Performance brakes and x Drive. Much Appreciated!
2016 340Xi M-Sport Sedan | BMW M Performance Exhaust l APEX SM-10 Wheels
10-26-2017, 10:28 PM | #2 | |
Rep 4,325
size wise, keep it simple 18x8 or 8.5,+35ish on 225 or 235/45/18 size tires. i haven't heard any company talk about their finishes being salt resistant. powdercoat is fairly durable but with salt i'd recommend a paint coating and cleaning them regularly(i know this is not easy to do when it's freezing out). a simpler face design would be easier to clean, obviously Last edited by alohasurftoad; 10-27-2017 at 01:18 AM.. |
10-26-2017, 10:49 PM | #3 | |
Rep 2,639
Very tiny poke front but flush rear. |
10-27-2017, 12:14 AM | #4 |
Rep 81
Drives: 2018 BMW 440i F32 Coupe 6MT
I chose 225/45 18x8 ET35 square, narrow tire better for snow.
10-27-2017, 05:02 AM | #5 |
No 55mph
1621
Rep 8,476
I just use the stock 400M 18" wheels that came with my car for winter setup
Purchased 19" 437M wheels for my summer setup
10-27-2017, 10:04 AM | #7 |
Rep 2,485
Drives: 340Xi MG 2017
I was looking for a winter setup for the 340 and decided to go with those in 18X8 / 35 with Nokian R2 225/45R18 shoes. They are winter approved and warranty is 2 years so no worries here. Fitment should be close to flush; but will need to confirm in a month or so when I put them on.
Not mounted yet so dont have a picture on the car for now, but it should look something similar to this : (328d shown)
10-29-2017, 07:30 PM | #8 |
Rep 109
I just got these on yesterday, Sport Edition P3 18x8. Not black but I prefer the gunmetal look.
View post on imgur.com Last edited by rogersmj; 10-29-2017 at 08:38 PM.. |
10-30-2017, 06:50 AM | #9 |
Rep 141
I've been using Apex EC-7 18x8.5et35 w/Pilot Alpin PA4 245/45 with Dinan Springs, I have had no issue with rubbing, and was easily able to handle 3-5" of snow/slush last winter on my commute from Maryland to Connecticut for my grandmothers birthday. Additionally wet and dry traction has been great with these tires.
2014 328i xDrive M-Sport EBII--M-Performance BBK/LSD/Aero--AA Signature Exhaust--Bilstein B6 DampTronic + Eibach Springs + H&R Swaybars + Millway Street Camber Plates + M3 Bump Stops + Dinan Shockware--Apex ARC-8 18x9.5et35+12mm Front Spacers w/Kumho Ecsta V730 275/35--FL-5/EC-7 18x8.5et35 w/Pilot Alpin PA4/Hakkapeliitta 10 Studded 245/45--BavSound Stage 1+Ghost Subs
11-15-2017, 07:57 PM | #11 |
Rep 219
Rial x10 18x8 wheels in 30 mm offset, Pirelli sottozero 3 MOE run-flats 225/45-18 all around.
Should clear the big blues, but unfortunately still waiting for the car |
11-16-2017, 08:34 AM | #12 |
Rep 2,639
Plenty of clearance, you need a minimum of 35 offset with 18s and 30 is way more than enough.
11-30-2019, 02:00 PM | #13 | |
Rep 82
12-02-2019, 08:17 AM | #15 | |
Rep 849
Drives: BMW 435i
I can confirm they will fit over the blue brakes with no issues at all. |
12-02-2019, 10:13 AM | #16 |
Rep 268
Here are Rial 10's 17" wheels with Continental Viking 7 235/50-17 tires. They are nice and beefy. I got the size up from 225/50-17 which is the stock size to 235/50-17. I wanted to eliminate cracked rims which I have experienced with 45 and 40 series sidewalls. I travel tough roads in winter and thin sidewalls are just not worth the risk to me.
12-02-2019, 10:23 AM | #17 |
Rep 849
Drives: BMW 435i
Do you like the tires? They were available in the 18" size I needed, but being new I didn't want to take the risk. I seldom see snow, but ice, sleet, rain, and sub-freezing are not uncommon.
12-02-2019, 11:04 AM | #18 |
Rep 268
I love these Continental Viking 7 tires. https://www.continental-tires.com/ca...ikingcontact-7
They are quiet, run smooth and comfortable. I am comparing them to Michelin Ice X tires that were the previous benchmark. Time will tell on ice and snow but these might be a smidge better as they are newer. Incremental improvement with each new model is what you are seeing with all car tires now. |
