03-12-2014, 06:31 PM | #23 |
Rep 702
Give it some more time and try different settings. If all fails, you could always swap out the drivers seat
2014 BMW 328i Sportline--Arctic White/Black, 8 speed
03-12-2014, 08:05 PM | #24 |
Rep 10,509
I think the lumbar support might be something specific to you, or your current seating position. I think personally if there is a gap between your lower back the seat back, that is a symptom that changes need to be made in your driving position
You can also try other stuff like putting a towel behind your back |
03-12-2014, 09:09 PM | #26 | |
Rep 1,267
The car is a lease and its pretty unlikely I'll swap out the driver's seat, seems pretty extreme. I did get this self inflatable lumbar thing in the mail today so we'll see if that helps. Absurd that its come to that honestly. Really its my only qualm with the car all in all. I can't fault the car for options it didn't come with except lumbar not being started is straight out of the dark ages but oh well.
2016 Black Sapphire 328i | M Sport Pkg. | JB+ | Premium Pkg. | Heated Seats | Driver Assist Pkg. | Navigation | Misc. Coding | 35% Ceramic Tint
Past: 2014 Black 320i | Sport Pkg | BMS Stage 1 |
03-12-2014, 09:20 PM | #27 |
Rep 933
Get a small lumbar pillow, problem solved
'14 Estoril Blue II F30 - 335i - ZMM - ZPP - ZTP - ZPS -
2TP Traded 9-1-13 '13 Estoril Blue II F30 - 328i - ZMM - ZPP -ZDY - ZTB - 403 - 465 - 494 - 4DX- LC (Black) - 6NL |
03-12-2014, 10:26 PM | #28 |
Rep 247
The seat bottom can tilt if you press the seat bottom button in a certain way. Lift the whole button to lift the seat. Slide the button back and forth to slide the entire seat. Tilt the front of the button to tilt the seat up and down.
03-12-2014, 10:46 PM | #29 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
Chiropractors can be quacks. Get a second opinion.
03-12-2014, 11:54 PM | #30 | |
Rep 1,044
03-13-2014, 12:01 AM | #31 | |
Rep 1,503
I personally fine the electric sport seats with lumbar support ok, just a touch too narrow. I didn't really need or want anything from the premium pack except the lumbar support, but I paid around 1k just for the lumbar support since I wasn't willing to risk the situation you're in. Good luck, hope you can swap into a car that fits you better. |
03-13-2014, 12:10 AM | #32 |
Rep 1,503
The switch that raises and lowers the seat - try twisting it clockwise/counter-clockwise to adjust the seat bottom tilt.
03-13-2014, 01:44 AM | #33 |
Rep 1,267
This came in the mail today and I drove for around 40min with it in as it's the best one so far.
https://www.thebetterbackstore.net/VARILITE.html Memory foam I've found is either too soft or firm but this combines air and foam and is easily adjustable. Perfect size too. We'll see how it is after a week or so by it's promising. Luckily the seating is really the only real qualm with the car and it drives beautifully. Getting out of my lease would either costs thousands, not an option, or swap a lease which I'd consider if the problem can't be resolved. We shall see. Self inflatable foam memory lumbar pillow. I don't want to be too optimistic But this one instantly felt the most supportive and "right" so we shall see. Some can be but not this one. I've had back problems for years and this guy is a keeper. This guy has saved my life before. I've thrown it out so bad where I couldn't stand up straight or get out of bed without help and this guy fixes me up every time. People without back problems have it made. I can't imagine how nice that would be Last edited by Kafkaesque328; 03-13-2014 at 01:56 AM.. |
03-13-2014, 04:20 AM | #34 |
Rep 6,222
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
I didn't read every post. I rather doubt this will help, but here's a suggestion. The seat should be at a good height. You should still have a bend in your knee when the brake pedal is applied with force. The back rest should be positioned so that your wrist rests on top of the steering wheel with your hand dangling over. I'm 5'8", too. I sit slightly farther back so that the heel of my hand rests on top of the steering wheel.
But, this is my actual suggestion - consider buying a power seat with lumbar support. I'm almost 100% certain the power connector will be wired in regardless of the car having manual seats. You may have to order a new OEM seat or you might get lucky and find one in a salvage yard. Check www.car-part.com Last edited by tturedraider; 03-13-2014 at 04:31 AM.. |
03-13-2014, 04:51 AM | #35 | ||
Rep 6,222
03-13-2014, 08:50 AM | #36 | |
Rep 1,003
Love my electric sport seats
People keep missing the point that OP has manual seats, NOT electric. With manual seats you lose the infinite adjust-ability and must find the best notch of each adjustment. Quote:
I see too many people leaning their seats back thinking it's more comfortable. The result is that they're forced to lean forward for visibility which puts a load on your body. Try driving awhile with the seat bottom flat or maybe even sloped down towards the front (takes much of the load off your thighs - at 5'8" you really don't need to extend the thigh support) and the seatback in an upright position. As in, comically upright. I mocked my dad for having his seat like this because it looks a little strange (no gangsta lean!), but in trying it I felt that it does work. Your upper body should be straight upright so that there is minimal bending in the spine, IMO. Scoot your butt back to where the seat bottom meets the seat back to minimize the effect of point 3 above. You can be truly upright in the seat, give it a shot and see what happens. I've read several of your posts, though, and maybe you're just fishing for a reason to get out of the F30? |
03-13-2014, 12:45 PM | #37 |
Rep 2,802
I have to get power seats all the time for this reason too. My 335 didnt have Lumbar which came standard in every Audi I have ever had so I never even thought to check. In manual seats i always feel like I'm falling forward. In one of my very first cars I actually shimmed the front of the seat rail. Worked pretty well.
03-13-2014, 12:58 PM | #38 |
Rep 156
I have the mechanical sports seats and am only 5'5"
Have them on the lowest setting and I have no issues. Just did a 6 hour round trip and felt fresh as daisy after. |
03-13-2014, 01:43 PM | #39 |
Rep 2,266
Come to think of it the 320d rental I had in Germany was manual seats and I did a lot of driving on the Autobahn with no issues. I'm only 5' 9".
F30 Sapphire Black M-Sport 335i 6MT
03-13-2014, 02:03 PM | #40 |
Rep 1,267
Well I may have found the 40 dollar solution to my problem. This inflatable lumbar cushion is great. Did a grueling hour long commute to work today with zero lower back fatigue. That same commute before this cushion left me with some kind of stiffness or low back pain every time. Best part is it doesn't stick out far so the side bolsters still hug the upper back and hold me in place.
It self inflates and you can deflate to meet desired firmness, very supportive without being hard. I googled bmw sport seats pain and a lot of threads came up so I'm glad I'm not alone. Still this is promising and I'm feeling optimistic. But anyway lesson learned. Next time I'll pony up the extra dough for the power leather with lumbar but I think this will be fine. Feeling alot better about the car today than I was yesterday |
03-13-2014, 02:56 PM | #41 |
Rep 343
IMO replace "can be" with "are". While I'm a major detractor of mainstream medicine as a whole I still view "alternative medicine" and anything based on pseudoscience the same as a snake oil salesman.
2014 335i M-Sport Mineral Grey / Sport Auto / Black Dakota / Aluminum Hex / Prem,Tech,DA packages / DHP / M-Sport Brakes / MPPK / MPE / Black Kidney Grilles, SS Pedals, M-Performance CF spoiler / Cameras, heated seats, etc etc
2013 X3 35i...wife's car |
03-13-2014, 03:22 PM | #42 |
Rep 1,267
No one with legit back problems see a good chiropractor as a snake oil salesman. The results have spoken for themselves time and time again for me. Just my personal experience. I've had times where I have slept wrong and woke up not being able to hold my head upright or turn it more than a few degrees to the right or left and a visit to the chiropractor instantly fixed it or at the very least, made a huge reduction in pain and a huge gain in mobility. I have 3 bulging discs and slight herniation. Most likely a combo of the following: serious car accident in highschool, several skateboarding and BMX accidents and 15 years of being a pro bass player, touring in rock bands. Having that added 10+ lbs hanging on one shoulder night after night for years at a time takes a toll.
03-13-2014, 03:41 PM | #43 |
Rep 27
After 3 weeks with my m-sport and the sport seats, my only complaint is the thigh bolsters are not adjustable .
Every guy I know likes to sit with their legs splayed open. Probably because we like to be ready to get felated at any given moment. But the bolsters kind of make that seating position uncomfortable . the protrusions stick into the bottom, sides of my thighs. Next time I'm getting the luxury line. |
03-13-2014, 03:51 PM | #44 | |
Rep 1,267
