12-03-2013, 12:51 PM | #23 | |
Rep 12,999
You should search for more details as this is outside the scope of the thread. |
04-27-2015, 02:59 PM | #26 |
Rep 14
Thanks for this thread!
First, I want to say thanks for putting up this thread, it was hugely helpful. I too had trouble finding a good remote tap in and did not want to go through the dash (iDrive pin 13). I found what I thought was the red/white wire that the OP tapped into for the remote, but it would not activate the LC2i. I ended up tapping fuse 159 in the fuse holder in the trunk, but it stays active for 13 minutes after the car is turned off. I don't think this should cause too much drain (the amp not pushing any music), but I would to know if there is any more insight into exactly what wire is tapped from the harness bundle to get a good remote that does turn off with the car. Thanks!
04-05-2017, 09:52 PM | #29 |
Rep 3
Best to obtain this stuff?
https://technicpnp.com/#homepage Technic's website with Paypal check out. |
02-17-2019, 05:10 AM | #31 | |
Rep 107
Do you have the pictures(especially diagram for hk) still? They are not displayed here Thanks |
02-17-2019, 09:11 AM | #33 |
Rep 49
The reports of my death are greatly exaggerated
OP still here, I no longer have the BMW but I still get notified of replies to this topic.
Not sure why the original images aren't coming through. Maybe my account got put in probation because I haven't been here in 5 years? When I went and looked for the original images everything started appearing again. Here's the HK diagram specifically but you should be able to refresh this thread to see all of the pictures again. Cheers!
2013 BMW 335i xDrive Sedan, Mineral Grey Metallic, 19" Light Alloy Double-spoke Style Wheels
02-17-2019, 10:49 AM | #34 |
Rep 16,079
They don't show up for me, and when I try to go direct to them this is the result:
The owner of www.f30post.com has configured their website improperly. To protect your information from being stolen, Firefox has not connected to this website. |
03-22-2019, 07:16 PM | #36 |
Rep 31
Will this be the same for the HIFI systems ? I want to add a 12 inch subwoofer to a 2013 bmw 328i f30. I have the lc2i and i want to know where and which color wires for the underseat woofers I will need to tap into. Where would it be the best to get the remote turn on and power for the lc2i and amp.
03-22-2019, 09:44 PM | #37 |
Rep 16,079
There are only two wires connecting to each under seat woofer, and you only have to tap one woofer because the low frequency content is summed to mono.
F30_ILLEST2.50 |
03-23-2019, 02:24 AM | #38 |
Rep 31
03-23-2019, 12:51 PM | #40 |
Rep 31
I've been looking and I can't seem to find a wiring diagram. Does anyone know the wire colors that run from the HIFI amp to both underseat woofers ? Would appreciate a response.
Lamora011531.50 |
03-29-2019, 02:22 PM | #41 |
Rep 178
What year and model? They are generally Black-Red++(pin 4)/Black-Brown--(pin 3) for Left and Blue-Red++(pin 23)/Blue-Brown--(pin 22) for Right. The colors sometimes vary, but the pins do not. Careful because there are duplicate colors (USW same as mid/tweet for that channel), be sure to confirm (larger gauge are USW).
What do you intend to do with that signal? You realize that is an extremely eq'd output signal? Since you have the HIFI you have access to a flat (mostly) analog signal from HU to HIFI amp. |
04-01-2019, 12:56 PM | #42 | ||
Rep 31
04-01-2019, 02:56 PM | #43 |
Rep 16,079
You only need to tap one USW. You can see the color of the wires by exposing where one attaches to one of the woofers. Using a harness is a better idea. Tapping the wires to one of the woofers is a necessity outside the US for those with base radios that have no separate amp.
04-03-2019, 10:29 PM | #44 |
Rep 123
Drives: x5 48i Msport
I have a technic harness for hifi that I’ll sell for cheap, then you won’t have to cut any wires
