05-16-2017, 10:29 AM | #1 |
Rep 2,654
2014 320i XDrive Retrofit iDrive Question
Hi everyone -
My 2014 320i XDrive came with the small head unit, no navigation and bluetooth telephone (no audio over bluetooth). It also came with the smaller iDrive knob (non touch). I basically wanted to upgrade the system to the 8.8 inch display with the new iDrive knob. I've looked around and there are so many different routes to go that frankly is overwhelming for me. Can anyone recommend a "kit" that comes with everything required to make the swap (preferably something plug and play if it exisits?) I've posted a pic of the options that came with my car below. I'm hoping there's something new out there that will fit the bill: View post on imgur.com |
05-17-2017, 10:06 AM | #2 |
Rep 740
Look into the vendor below...also, look into NBT retrofit (non ID5). Since you have HU_entry, retrofitting NBT should be almost easy.
https://www.bimmer-tech.net/shop/bmw...tion-retrofits
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
05-17-2017, 06:29 PM | #3 |
Rep 193
Go for an EVO ID5
05-17-2017, 06:31 PM | #4 |
Rep 2,654
05-17-2017, 06:46 PM | #5 | |
Rep 193
different in everything bimmertech supplies the evo too! |
05-18-2017, 08:43 AM | #6 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
2014 models have a combox which means that your microphone, USB and Bluetooth are running to the trunk. If you go with our retrofit, it will be 90% plug and play but you will still need to run a replacement mic cable from the A pillar over to the main connector of the head unit which isn't too bad. We also send you a replacement USB cable and Bluetooth antenna so that you don't have to run those from the trunk back up to the front. Everything is pre-programmed on our bench before sending to you so it is all FSC activated and coded to your vehicle spec.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 05-18-2017 at 09:50 AM.. |
05-18-2017, 01:54 PM | #7 | |
Rep 2,654
05-18-2017, 01:57 PM | #8 |
Rep 1,976
Yes, we will need to make some coding modifications on your existing setup so that there are no conflicts with NBT. We provide ENET cables for all NBT ship outs in case any follow up coding is required. Coding is done over Team Viewer on your Windows or Mac laptop over your Wi-Fi or Mobile Hot spot connection.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
05-18-2017, 02:02 PM | #9 | |
Rep 2,654
05-18-2017, 02:09 PM | #10 |
Rep 1,976
Check PM.
