03-29-2021, 05:57 AM | #1 |
Rep 47
340i - Lots of white smoke after idling a while
Recently, my 340i started giving off a lot of white smoke from the exhaust after idling for a while, like a hour or less. The smoke normally comes after a rattle from the engine from what I can only assume is the turbo.
Now, when this happens, I switched the car off, wait for about 30 seconds, and start it back up again. I then start driving, and the smoke and rattle goes away, almost as if it fixed itself instantly. The car doesn't appear to be in limp mode or anything of that sort, and the car appears to have all it's power on tap. No lights on the dash come up, and no errors in iDrive come up either. It's as if the issue doesn't exist. Vehicle status shows up green. My car is out of warranty and motorplan, and is completely and utterly stock. No modifications have been do this car at all. Car has got 76K KMs The car has never been beat on, only a few spirited drives here and there whenever I have the chance to enjoy it. I think it might be the turbo housing, but I could be wrong. Is this a known issue with the B58? Does anyone have any idea why this is happening, and what could be causing the issue? Any insight would be greatly appreciated! Thanks for viewing! |
03-29-2021, 06:00 AM | #2 |
Rep 439
First question is, why are you idling for up to an hour??
floridaorange10165.00 |
03-29-2021, 06:05 AM | #3 |
Rep 47
I'm normally the driver for my parents when they go around town doing their errands. Usually I have to sit in the car, because of COVID and crowded places, with the AC running on low, due to the heat, while I wait for them to finish whatever they are up to.
Could the AC be the problem? |
03-29-2021, 06:28 AM | #4 |
Rep 439
No, the extended idling is the problem. You are probably getting a buildup in the exhaust due to incomplete combustion from idling. You are also probably getting fuel diluted into the oil and will have to change your oil more often.
Stop idling for more than a few minutes, turn the car off, put a mask on, and stand outside. |
03-29-2021, 06:36 AM | #5 |
Rep 47
Hmm. Who would have guessed extended idling? I sure as hell wouldn't have guessed it. I thought these engines would be fine with the idling, considering what they are all cracked up to be.
Note to self, don't idle the car for so long! Thanks for the help, Th3Walrus. I really appreciate it. |
03-29-2021, 09:02 AM | #6 | |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
03-29-2021, 06:26 PM | #7 |
Member
106
Rep 151
PCV diaphragm. Here's what you need:
https://www.ebay.com/itm/Membrane-Va...EAAOSwOxVgACU6 |
03-29-2021, 06:32 PM | #8 |
Rep 188
Drives: '14 BMW 640i Gran Coupe Msport
I’m not sure about the extended idling causing the smoke. While extended idling is not good on any car, especially turbo cars, this sounds like an oil leak.
Maybe a valve cover gasket leaking in an exhaust, causing the smoke? Or bad pcv? |
03-29-2021, 08:43 PM | #9 |
Rep 4,877
These things idle so low and so lean, I doubt you have any fuel in oil dilution issues. Heck, if your commute involves a lot of gridlock, that can be an hour of basically idling, daily.
I'd suspect you have some sort of oil leak though. Maybe PVC as mentioned above? |
03-29-2021, 08:48 PM | #10 |
Rep 6,001
I had this problem to, once it happened while waiting in a COVID drive thru with other cars idling for long periods but they didn't have any problem. Had to shut it off and turn it back on. Think there's an issue with the design. Dealer could not find the problem or there is no solution so they say there's no problem.
03-29-2021, 09:11 PM | #11 |
Member
106
Rep 151
This is very common on the early year B58s. Just check the B58 facebook group, it's happened to dozens of people there. All had two things in common:
-Happened after idling for an extended duration -2016 B58 (maybe one or two 2017s) The problem is the rubber diaphragm gets tears in it. |
03-30-2021, 10:27 AM | #12 | |
Rep 47
At least I know I ain't going crazy thinking that it could be a blown head gasket. |
03-30-2021, 10:28 AM | #13 | |
Rep 47
03-30-2021, 10:32 AM | #14 |
Rep 47
Welp. I was always under the impression that the new six cylinders, diesel included, from BMW where tough as nails. I would never had thought that something as stupid as idling for a bit would have such a big affect.
03-30-2021, 10:33 AM | #15 | |
Rep 47
Does anyone know if FCP Euro keeps this part? I can't find it anywhere on their web store. |
03-30-2021, 11:22 AM | #16 | ||
Rep 6,001
03-30-2021, 12:35 PM | #17 | |
Rep 47
I just might do that and take it to a indie shop to get this issue sorted. No point in turning a blind eye to this issue. |
03-30-2021, 03:39 PM | #19 | ||
Rep 6,001
03-31-2021, 02:32 AM | #20 |
Rep 47
Best to diagnose before jumping the gun. I'll update this thread the moment I know what is wrong with my engine, and how we fixed it.
03-31-2021, 02:41 AM | #21 | |
Rep 47
Thanks for the video vmaniqui. This will tell me what the PCV valve does in a BMW engine. |
04-03-2021, 08:18 AM | #22 |
Rep 439
340i, 340i issues, 340i turbo, idle, rattle, white smoke |
