BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Intermitent starter failure
      02-10-2024, 10:49 AM   #1
antonius2018
Drives: BMW F32
Question Intermitent starter failure
In recent days, sometimes the car only starts on the second attempt.
I had ISTA read the errors and got:
8040B5 Engine start fault during starter operation. No engine speed on activation.
80444D Inside mirror: Undervoltage detected
804970 Seat-belt extender on driver’s side: undervoltage detected
804980 Belt reel unit on front passenger side: undervoltage detected
B7F8C3 Connection, headunit CID: No communication ( this last error results from changing the CID with an Android radio).
The voltages I receive on ISTA are as follows:
Voltage supply:
terminal 30F State 14.90 V
terminal 15 State 12.00 V
terminal 30L1 State 15.00 V
terminal 30L2 State 14.90 V
(I also measured directly with a multimeter the voltage with the engine off wich is 12.90 V and with engine on which is 15.30 V.).
The seat belt undervoltage occurred in January 2023, so it appears to have gone away in the meantime.
I don't have any symptoms of a bad battery, as everything works fine.
I had the Start-stop activated till the first fail, but no more.
It looks like I realy have a faulty starter motor that I need to replace.
Any other ideas or help with this problem?
Thanks!
error 8040b5, starter motor
