01-12-2014, 02:52 PM | #1 |
Rep 13
2014 320i n20 ActiveFlex (100% ethanol)
hi guys!
I have, in brazil, a 320i 2014 equiped with n20 engine activeflex. This engine runs, originally, with gasoline, 100% ethanol or a mix of both! It have a sensor in a gas line that recognize what combustible is on the tank, change de a/f mixture and set the ignition time. Then i have a question: Can I use a BMS stage 1 on my car? will i be most power using ethanol? if I run in a stage 2 , can I use more boost using ethanol? Wambier Last edited by Wambier; 01-12-2014 at 05:40 PM.. |
