08-28-2013, 03:53 PM | #1 | |
Rep 5,824
BMW Z5, Z1 and Z3
Featured on BIMMERPOST.com Quote:
There was the plan to absorb the Z4 iS into the M Performance line but this fell through in the final hour. We will shortly be presenting our collaboration with Toyota for a new interpretation of a new highly focused sports car first as a concept. The production car will be called the Z5 which allows us to align a new UKL (FWD) based Z1 with equivalent MINI sports car along with a mid sized Z3 (the name is coming back) which again could be aligned with Toyota. Although for some markets Toyota might use Lexus branding. The Z5 Roadster will feature exterior and interior design from BMW, as well as BMW engines. Toyota will supply optional hybrid technology and BMW will supply CFRP in its construction. A coupe will follow. The new "Z" design is influenced by the Vision ConnectedDrive Concept Car. * Image below used for illustration purpose.
The M850i is evidence that BMW have got their mojo back when it comes to dynamic sports cars...
08-29-2013, 01:05 AM | #3 |
Rep 10,509
WOW. great info thanks.
Your earlier post suggested the need to do a sports car "right" and it is now followed up with a post about "highly focused" fixed roof coupe with CFRP, BMW styling and engines. This is really exciting! If I may suggest, please have the option for a non adaptive "Track focused" suspension option. I personally find that the adaptive dampers on my Z4 do not have enough compliance so I can not use curbing on corner exit and if it is a bumpy corner exit I can not get the power down quickly. Also, in transitions in rapid succession, such as a slalom exercise, it seems like the suspension starts to compress differently at the end. Perhaps all the weight moving around quickly plus the driver scrambling to recover is a hard math problem for the computers? I think a traditional "track focused" suspension would be more predictable. Lastly, it would be great to have extra cooling for the car (even if it is extra cost package, like M Sport brakes, that is fine) because the Z435 right now can not withstand a standard 25 minutes performance driving school session. It will get into power reduction mode and then limp mode easily. Jamesons Viggen if Z4M were an $80k car that delivers performance that is on par with other similarly priced cars like Z06 and GTR I don't see any reason why people wouldn't pay for Z4M. The problem comes when you have a $75k 35is that can not complete with $45k C6 Z51 or even $50k 1M. |
08-29-2013, 08:44 AM | #4 | |
Rep 3,780
08-29-2013, 08:50 AM | #5 |
Rep 9,160
Agreed, the E89 is beautiful, but too big and heavy.
When I bought my E36/8, it was small and there was no Cayman yet. The E85/86 was still a less polished and cheaper competitor than the Boxster/Cayman. Now the E89 has sort of lost the plot. Hopefully they get back on track, Scott's info sounds promising. |
08-29-2013, 03:22 PM | #7 | |
Rep 6,309
F30.F11.E86.E90.E90.E36 |
08-29-2013, 03:22 PM | #8 |
A family of bimmers
2745
Rep 7,741
i thought 1,3,5 were aligned for 4 doors while 2,4,5 were aligned for 2 doors.. why wouldn't it be Z2, Z4, Z6? because there are already convertible counterparts?
i'd love to see a boosted Z2 but in proper wheel drive.
08-29-2013, 03:49 PM | #10 |
Rep 3,446
Did I read front wheel drive?
See my photography at http://ronscubadiver.wordpress.com
08-29-2013, 04:00 PM | #12 |
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
If ///M builds the Z5 Coupe as nicknaz has requested (track focused), I would be first in line to order.
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
08-29-2013, 04:04 PM | #13 |
Rep 617
Very nice... The Z4 is THE BEST looking roadster on the market. Previous a d gen and current model. The coupe from the previous gen will go down as a classic, mark my words. BMW just knows how to do 2 door and coupe profiles so well IMO.
08-29-2013, 04:05 PM | #14 | |
Rep 10,509
Curious if any other posters have tracked E89. I am pretty clear that the E89 is a street car / cruiser but it is not horrible to track (other than the insufficient engine cooling!!) and with similar tires it would be interesting to see how much pace (if any) E89 would give up compared to E85/6 M All that said, 3500lb and retractable roof are not insurmountable. Jag F type is an interesting example of a heavy roadster with big power and the correct equipment that is doing well for itself with the journalists EDIT: I thought of another change request.. the launch control. Please have it so that it cuts timing (and makes cool noises) to limit wheel spin and have the adjustable rpm setting so that it is not a 4000rpm clutch dump with a lot of wheel spin. On the stock tires, I am able to cut a better (but still poor) 60ft with the gearbox in D mode and car in sport+ rather than using the launch control Last edited by nicknaz; 08-29-2013 at 04:37 PM.. |
08-29-2013, 04:08 PM | #15 | |
Rep 4,323
08-29-2013, 04:09 PM | #16 |
Rep 487
I wanted them to be called Z2, Z4, Z6, Z8, or even numbers, but marketing department triumphs all. They have to use Z1 because that car is going to be FWD and they don't want Z1, Z4, Z6, odd and even numbers.
"Z" already means 2 seater coupe/roadster so I'm ok with it. Unless the Toyota Z5 is 2+2... |
08-29-2013, 04:11 PM | #18 |
DHS
200
Rep 4,005
Drives: 2023 M4, 2020 Land Rover
You did.
This will probably rival the new Honda Civic SI platforms or other high revving FWD platforms. Not to be confused or anywhere near the F82 M or E9X M platforms in terms of performance.
2020 Land Rover Velar Autobiography
2023 BMW M4 2016 X3 |
08-29-2013, 04:17 PM | #19 |
Drop-Top Turbo
181
Rep 598
Drives: 2013 991 C2S/ 2013 335is E93
I think they mean only the Z1 will be FWD. LOL, so BMW is developing the design, engine, and chassis... and Toyota supplies a crappy hybrid powertrain. Why is BMW even bothering working with this company when they are doing all the work.
Current 2013 Porsche 991 Carrera S [Agate Gray] [Black] PDK, PASM, Sport Chrono, Sport Seats, Sport Techno Wheels, BOSE
Current 2013 BMW 335is E93 [Mineral White] [Coral Red] DCT, Premium Pkg, Convenience Pkg, Nav, Heated Seats, HK, BMW Apps |
08-29-2013, 04:24 PM | #20 |
Moderator
7510
Rep 19,370
Great to hear that this is still on the roadmap; even better with CFRP in the mix.
Another older post on the topic: http://f20.1addicts.com/forums/showp...5&postcount=40 In the past SCOTT has said that what they might do for the Z cars is switch the roadsters to odd numbers while the coupes will be even numbered. I am not sure if that is still the plan, but if the roadsters are indeed going to be odd numbered as he mentions above, then it could be the that the coupe versions of them (which he also mentions are in the works) will get even numbers. |
08-29-2013, 04:34 PM | #21 |
10802
Rep 27,594
need more info! this is very cool
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
