BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Run-flats durability & longeivity
European Auto Source
      11-08-2012, 10:41 PM   #1
bmwdrvr13
Drives: 328i
I have never had run flats before. Judging from previous posts longevity is around 15k-20k miles. They seem to hold up ok, again just from reading. If I were to switch to regular tires after the RF's wear out, would it be a fairly simple process? Do I have to change pressure sensors for the regular tires? I would appreciate the feedback. Thanks in advance.
      11-08-2012, 10:49 PM   #2
claykin
Drives: 2016 535i M-Sport
RFT tire wear will vary by your driving style as well as road surface condition. i.e. in Florida, some of our roads have ground up coral, shells, etc. in the asphalt and this can be hard on tires.
If you change to non RFT tires, no need to worry about pressure sensors, etc. All will work OK. Just consider a patch/inflation kit in case you get a flat.
If I was to worry about anything its to find a tire shop that has a leverless tire changer such as the Hunter Auto34. http://www.hunter.com/tirechanger/auto34/index.cfm. This helps to insure your rims don't get chewed up when changing tires.
      11-08-2012, 11:39 PM   #3
azzurro
Drives: 2013 335i M Sport
I'm planning on using my 18" summer performance tires for a year and then swapping to new wheels and non run flats, probably Hankook Ventas V12's with a patch kit.
Swapping out the new tires & wheels and trying to sell them on Ebay seems like a PITA which is why I wouldn't do it immediately. What are others doing??
      11-09-2012, 08:52 AM   #4
Orient330iNYC
most of the issues with runflats have been ironed out in the current generation of tires, with ride harshness being the top of the issue list.
impact damage (pothole induced sidewall ruptures aka bubbles) should be lessened now that bmw has increased tire diameter from 25 to 26-- an F30 running on 18s has the sidewall height of an E90 running on 17s.
Past: 2004 S60R 6MT
Past: 2007 E90 335i 6MT
Past: 2010 335xi ZMP, MPPK, MPE
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
      11-09-2012, 02:45 PM   #5
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
the new run flats are actually pretty great - I'm driving the AS version of them, and the ride is smooth, corners well for an AS, and honestly, I'd consider re-purchasing them again if I upsize my wheel package into a staggered configuration (225/45 front and 255/40 in the rear, in 18's).
SOLD: 2012 335i Mineral Gray
