05-01-2021, 08:05 PM | #1 |
Rep 15
Traction Control Light on
Hi
My Traction Control Light on Showed up today and it slowed the vehicle.I switched it off and drove. .During Regular Service they mentioned my Rear Brake Pads are 4MM and Recommend performing rear brake service with Rotor Replacement.Rotors have excessive Rust on Inner Side Causing poor Pad contact. Gave me a Quote of $859 Is it the reason for this Light on? Please suggest. 430 Xi GC Last edited by vharish006; 05-01-2021 at 08:14 PM.. |
05-02-2021, 03:07 AM | #3 |
Rep 496
"My Traction Control Light on Showed up today and it slowed the vehicle.I switched it off and drove. "
That was what happened to me (many years ago) when the ABS sensor needed replacing. I don't know if it still works this way nowadays (I haven't had ABS sensors problems with my recent cars). After you've had your brake work done, if the light is still on, then look into this possibility. |
05-02-2021, 11:48 AM | #4 | |
Rep 1,641
05-02-2021, 12:19 PM | #5 |
Rep 16,184
Get a second opinion. A ridge of rust on the outer edge of rotors is normal, and is easily removed. It takes a lot more than that to require replacing rotors. It shouldn't have anything to do with traction control. You may have even turned the light on inadvertently.
05-02-2021, 12:31 PM | #6 |
Rep 496
05-04-2021, 04:59 PM | #7 | |
Rep 14,141
Drives: G82 M4C X-Drive
OP: Traction control will also cut power along with apply brakes to wheels that have lost traction, but that loss should go away as soon as your car regains composure. Was it a permanent power loss, or momentary? The traction control light that went on, was it a WARNING light or a light that says you turned if on/off?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
Tags |
tires, traction control |
