01-29-2018, 08:07 PM | #23 | |
Rep 4,333
shortened bumpstops such as dinan supplemental handling kit will mitigate some of this by reducing the total shock length. to me, if you have adaptive with lowering springs, shockware is imperative. shockware doesn't work on regular susp. bilstein b6 and koni orange are meant for stock to small lowering. it'll likely okay enough for you and be cheaper than coils but you never really know what you're getting when you mix and match. everyone's handling/ride/satisfaction scale is different, so you'll have to inform yourself by reading threads/post here and decide. i suggest an entry level coilover like bilstein b14 pss or kw street comfort. preset damping, matched springs, adjustable height. a lil more pain on your wallet initially but once it's in, height is set and alignment done, move on to next project. re-doing and chasing stuff costs more than initially paying more for something better, most of the time. Last edited by alohasurftoad; 01-29-2018 at 08:14 PM.. |
01-31-2018, 08:16 AM | #24 | |
Rep 937
I don't have DHP, so if I were to end up doing springs I'd feel comfortable with dinan's 10mm lowering springs and bump stops. Then if I notice my shocks getting bad I'll upgrade the shocks to something else (after researching). How does that sound for a plan? It makes sense to me, but I rather have your opinion. And yeah I totally agree with your last sentence. Most of the time it's better to bite the bullet and spend the cash to get something than jump around.
Hi
01-31-2018, 09:50 AM | #25 | |
Rep 4,333
i suggest reading through this and forum search dinan springs. i think dinan lowers more than 10mm. i've read 5/8" front, 3/4" rear, 3/4" front & rear, 20mm. in the pics i've seen it appears to be 20mm and apparently some have had problems with reverse rake. during a lowering spring install the front requires a spring compressor and is a big part of the labor cost. since everything is apart during installation, changing the struts/shocks at the same time makes sense to me. also, every time you change suspension components requires an alignment, keep this in mind because it will add up when you keep re-doing stuff. since everything is apart, at minimum, replace the stock struts/shocks with bilstein b6/b8 or koni orange/yellow, you'll have to research this as well i've seen varying reviews, too bouncy, reverse rake, etc. this is the problem with mix/match. my opinion is go straight to the bilstein b14 pss. it costs just a little more than springs+aftermarket struts. since it's just height adjustable, installation cost should basically be the same as installing just springs. i prefer no guessing...install once, align once, refill wallet, move on to next project. but it's not my wallet so you do what you gotta do. |
01-31-2018, 12:05 PM | #26 | |
Rep 937
I'd be doing it myself so that makes sense to just do it all at once not only for the time, but the alignment cost that I didn't think of. I'll do some research, as long as comfort is similar to aftermarket spring/strut combo then I'll definitely just bite the bullet and go for the bilsteins. Thanks for your advice, I appreciate it!
Hi
01-31-2018, 01:59 PM | #27 | |
Rep 4,333
01-31-2018, 06:03 PM | #28 | |
Rep 937
We'll see. And I'll definitely do plenty of research before biting the bullet.
Hi
02-01-2018, 01:16 AM | #29 |
Rep 4,333
Tags |
dhp, dynamic handling package |
