09-05-2013, 12:44 AM | #23 | |
Rep 1,135
The Scroll Wheel on the steering wheel is there to scroll through lists. That's all it does. It is a shortcut for a function that is buried in iDrive and reduces driver distraction. It's why it's there. The Skip buttons on the center stack are there to jump tracks. That's all they do. They are not that far away and are easy to locate without looking. And since 99% of Media users are using Random only 1% of the time, the solve for this is quite simple: To skip to the next track from the steering wheel, just rotate the scroll wheel one notch downward and press it in. There. You've skipped. You don't even have to glance at the HUD. Same as hitting the Skip button. And I, for one, like the fact that when in Random I can use the Scroll Wheel on the steering wheel to instantly get to the next song from that artist and defeat Random. So if I'm listening to my 100 song 'High School Mix' playlist and I hear a cut from Bruce Springsteen and want to hear more Springsteen I only have to scroll the wheel one notch downward, engage his next track, and not have to go into iDrive submenus to uncheck the Random box. |
09-05-2013, 12:48 AM | #24 | |
Rep 1,135
Each app functions differently depending on how it was programmed by the developers. Pandora, for example, is not engineered by BMW but rather by Pandora and they've decided that you can skip to the next track but not back and there are no previews or anything of that nature. That was their decision just as the developers of all the other apps made their own UI decisions. Your older iDrive system also provides greater data and control when these apps are run over USB than when attempted via Bluetooth. |
09-05-2013, 01:54 AM | #25 | ||
Rep 1,093
Has a bad car addiction
09-05-2013, 03:01 AM | #26 | |
Rep 173
I tested it earlier today on an iPhone 4 that was running iOS 5. I also played around with it a bit on an iPhone 5 running iOS 6 but I'm not sure if I turned random on or not. |
09-05-2013, 03:08 AM | #27 | |
Rep 173
One of those circumstances is when streaming from an iDevice running an app that doesn't provide track info. This I can personally attest to. The other case is (at least) some non-apple BT streaming devices, as others have attested to. Disclaimer: I know some of this has changed with NBT and/or iDrive 4.2. I don't have a car with a CIC in it any more and some of the things being discussed I tried maybe once w/ CIC a year+ ago so I'm having trouble keeping track of what nuances are specific to what. Last edited by JesseS; 09-05-2013 at 03:22 AM.. |
09-05-2013, 04:45 PM | #28 | |
Rep 1,135
iDrive as standard equipment. Premium sound system as standard equipment. HD Radio as standard equipment. Bluetooth as standard equipment. BMW Assist as standard equipment. Instrument cluster with enhanced contents. Black plastic reduction on the center stack. Gloss chrome console trim. Aluminum electronic auto shifter. Thicker, contoured steering wheel. Enhanced ambient lighting with red/white option. Superior cup holders w/tray cover option. Larger air vents for superior cooling. Curved instrumentaion surfacing for cockpit feel. Hidden compartment beneath headlamp switch. Auto dimming exterior mirrors Auto dimming rearview mirror Universal garage door opener Power seats w/memory Split & fold down rear seats A 2009 Post-LCI E90 had an MSRP of $33,600. The 2013 F30 has an MSRP of $36,850. Using an inflation calculator, $33,600 in 2009 is equal to $36,483 in 2013. So that laundry list of standard features and improvements I posted above has a true out-of-pocket real-world incremental cost of $367. Cry me a river with your BMW "fail". |
09-05-2013, 04:46 PM | #29 | |
Rep 1,135
The streaming apps are just that- APPS. Apps created by third party developers who chose their own implementations. If the Pandora engineers decided not to activate the skip forward/backward feature in the HUD that's on Pandora, not BMW. Savvy? |
09-05-2013, 10:07 PM | #30 |
Rep 345
At the end of the day, BMW's integration via Y-cable sucks. Don't know how many times the iDrive isn't even in sync with the playlist I picked and I have to disconnect the mess.
Maybe those with Enhanced BT and NAV have better luck. The 2k for that crap probably isn't with it. When in random the scroll wheel should act like the arrow buttons on the head unit and go to the next random tune. Not hard to do. Our krappy Toyota can do this. |
09-05-2013, 11:21 PM | #31 | ||
Rep 1,093
The F30 is supposed to be an improvement over the E90. It is expected to be better. If you are saying that adding one feature means taking another away - especially if its a basic one that the competition offers - that's like saying your new house has a bigger kitchen than the old one, so you decided to not have a bathroom this time.
09-06-2013, 04:49 AM | #32 | |
Rep 173
09-06-2013, 04:54 AM | #33 |
Rep 173
Why is this ("next random tune") better than showing you the entire random track list and allowing you to select whichever track you want? (As the current implementation does when using an iDevice)
09-06-2013, 06:21 AM | #34 | |
Rep 345
09-06-2013, 07:21 AM | #35 | |
Rep 173
So, you are either comparing old or faulty technology with your assumption of how the tech should operate now (or even then). It's like saying: "Brand X in 1989 didn't have this feature that Brand Y does now" or even "Brand X in 1989 didn't have this feature that Brand Y had in 1989". Either way you're comparing historic technology and that isn't a very useful statement in terms of what the F30 is and can do. If someone were to read your post without context they would come away with the mistaken impression that the F30 lacks this capability. It does not. |
09-06-2013, 07:46 AM | #36 | ||
Rep 345
My post isn't misleading. Apparently your the only one sofas that seems to have the "new technology" that we are all envious of. |
09-06-2013, 09:16 AM | #37 | |
Rep 173
I have a car from 2010 which was considered high tech then but now seems almost primitive by comparison to what's available in 2014 models (from many different manufacturers). Presuming this feature is due to changes in iDrive 4.2 that means everyone with an NBT head unit has it or can get it. That's all 2013 AH3s in the US and wherever else BMW chose to roll in out in the F30 (varies by region). At this point you cannot buy a new model year F30 without getting an NBT. There's also the chance that it's the result of some other update that doesn't require an NBT. Service depts don't upgrade all the ECUs every time you take your car in, they only do it when there's a problem they are trying to fix or a mandatory "recall". Last edited by JesseS; 09-06-2013 at 10:47 AM.. |
09-06-2013, 10:45 PM | #38 | |
Rep 1,135
When you strip the hell out of it because you can't afford it configured properly, well, you get what you pay for. The scroll wheel is a luxury feature for those who bought the car the right way- with the HUD. It's not some workaround for a pedestrian feature found on a Toyota for those that probably only can afford a Toyota but are cutting corners to get into a BMW. |
09-06-2013, 10:49 PM | #39 | |
Rep 1,135
The typical jealous E90 owner just sticks to his crappy "the interior is made of inferior materials" theory. This "scroll wheel disappointment" is really ridiculous. Some day when you can afford a $50,000 BMW configured as the German designers intended, you'll have the HUD and won't need a skip button on the steering wheel. The only time that the scroll wheel might be a minor issue is when listening to an iPod on random, and if you can't afford the HUD you can't afford the iPod either, so it's a moot point. |
09-06-2013, 10:52 PM | #40 | |
Rep 1,135
It sounds like we're on the same side of the debate then- if streaming doesn't allow forward/back skipping its is for one of two reasons: 1. The F30 owner didn't add the Enhanced Bluetooth and USB option. 2. The app developer didn't add the forward/back function to its app. Neither eventuality is BMW's fault. |
09-06-2013, 11:12 PM | #41 | |
Rep 1,093
Who is trying to talk themselves out of anything? We are all BMW customers - and like you said, ex-E90 owners, most of us - making observations from our expectations and experiences. It sounds like you are the one frantically trying to talk yourself out of every negative observation everyone makes. Really, do you work for BMW? And come on, do you know what an iPod costs these days? |
09-07-2013, 01:35 AM | #42 | |
Rep 13
Back on topic my $50k March build 2013 335 doesn't work like i'd expect with my iPhone 5 (64gb latest OS) or my wife's iPhone 4S when streaming music from either phone. No 3rd party apps etc, just using iTunes playlists. As many have stated, when Bluetooth streaming there is no way to change the song from the steering wheel. I do usually like to have it on random, but even with random off the same thing happens. The HUD shows the current song title and that's it, scroll all you want, it just shows the current song. If I plug the phone into the USB port I am able to change the song from the wheel, but when I can't do the same thing over BT even though i paid extra to get the enhanced BT that is disappointing no matter how you spin it. Especially when this feature was possible on the older car and on much cheaper cars. I bought a $50k car, I should 't get in my sisters $20k Mazda3 and wish my BMW had features that hers does (being able to stream BT playlist and change the song using steering wheel controls isn't to much to ask). Reading some of the constructive comments it seems if you have an android phone you can change songs with the wheel one way or another. I would be very happy with that, but as it is I have an iPhone and can't, and I'm clearly not alone in being disappointed with the "luxury" wheel feature. Flame on. |
09-07-2013, 03:40 AM | #43 | ||
Rep 1,093
09-07-2013, 08:43 AM | #44 | |
Rep 173
Car design is a time intensive process and thus they often lag behind the latest tech a bit. However, BMW has most certainly updated with the latest MY tech and now fully supports a working AVRCP 1.4 implementation (which also gives you additional metadata like cover art). That being said you might want to make sure you've installed the latest updates. Some updates are user installable and I recall reading that BMW has recently released an update specifically for bluetooth+smartphones. It may have fixes necessary to correct AVRCP 1.3 and IIRC, it does sound like your manufacture date falls within the supported range for the update. Whether you have the pre-requisite options I obviously cannot say. |
