View Poll Results: Did you experience timing chain failure on your N20 engine? | |||
Yes, my timing chain failed or required replacement. | 33 | 14.47% | |
No, I have not experienced timing chain failure. | 187 | 82.02% | |
I replaced my timing chain as a preventative measure. | 8 | 3.51% | |
Voters: 228. You may not vote on this poll |
06-18-2019, 08:32 AM | #45 |
sucka for a longroof
29
Rep 70
Model: MY 2015 F31 328ix, 12/10/14 build date, USA
Mileage: 21.5k miles Timing Chain Status: No problems Oil Changes: Low mileage CPO - 5.5k, 11k, 13.2k, 13.5k from service history; changed at 20k since my ownership Stop/Start Coded Status: Coded off |
sspade2468.50 |
06-18-2019, 08:41 AM | #46 |
Rep 420
Model: 2013 F30 328i Sport RWD 8AT
Build: not sure, will try to check later Mileage: 106,000 miles Timing Chain Status: No whining yet. Loud tick on cold starts, hoping DI noise. Need to check chain from oil cap. Vaccum pump failed around 50k, not sure if chain was replaced with the pump..... Oil Changes: Done at factory intervals. |
sspade2468.50 |
06-18-2019, 01:34 PM | #47 |
Rep 429
2013 X3 28i. 82k miles. Heard whine and took into dealership. Called BMW NA and they paid 50% despite it being 14k out of warranty (owning more than 1 BMW may help) Timing chain/oil chain replacement, no engine damage. Everything serviced at BMW on time or earlier, no mods. Also, regional rep who looked at car told my SA to tell me to save my receipts for repair. Not sure why. Additional goodwill compensation or class action?
IMHO, the internet makes some issues appear worse then they are, however, in my opinion this issue is worse than it appears because it isn't model specific. No good single place to aggregate all the info. Last edited by M2 CSL; 06-18-2019 at 02:16 PM.. |
CandyRedRC46242.00 |
06-18-2019, 10:31 PM | #48 |
Rep 500
As promised, here’s the photos for the rail guide. It’s broken at 2 different places. Luckily I get it replace before anything major happen. My auto start stop is coded off since day 1 and service every 10000km. So I don’t think that’s the root cause as this is clearly manufacturing defect. My service advisor also show me another car that had the same problem. The owner heard whining noise and bring in for repair. Looks like this might occur no matter how much care taken for the engine.
I voted under preventive maintenance but should be under problematic category. |
06-19-2019, 12:04 PM | #49 |
Rep 2,676
I've read this issue is related to all N20 engines produced before 1st of March 2013. Can anyone shed any light on this?
My production date was June 19, 2013 No issues. Oil Changes every 5k miles. start/stop coded off soon after I purchased it. |
06-19-2019, 12:54 PM | #51 |
Rep 212
Model: MY 2013 328i . July 10, 2012 build date. Germany.
Mileage: 116k miles, mostly highway miles Timing Chain Status: No problems Oil Changes: Every 10k miles since 44kmiles; I change the filter every 5k miles and top off. Always use LL-01 5W-30 0il Stop/Start Coded Status: Coded, always off since 50k miles. |
sspade2468.50 floridaorange10276.50 |
06-19-2019, 02:03 PM | #52 | ||
Rep 5,458
Drives: F30
06-19-2019, 02:41 PM | #53 |
Rep 155
Thought I'd share - I work in the industry writing service for a Non-BMW branded dealer. I've come to know an experienced tech in the highest volume bmw dealer in town and he mentioned to me that they have maybe done 2 timing chain jobs ALL YEAR. These guys do more volume in sales and service than any other BMW dealer in town, maybe even the country.
Take that for what it's worth. Seems to be reflected in the poll answers in this thread with majority saying no issues. |
06-19-2019, 03:27 PM | #54 | |
Rep 943
Drives: F30 328i Msport
06-19-2019, 04:14 PM | #55 | |
Rep 429
06-19-2019, 06:51 PM | #56 |
Rep 500
Just to let you guys know before I do the replacement, I didn't hear whining noise although the TC guide is broken. So, doesn't means that there's no problem without the noise. Also, before I bring in the car for timing chain replacement, my SA try to downplay the issue when I talked to him. After confirming the issue, the mechanic mention to me the plastic looks kind of too thin and always break at the same place. If you think they honestly will tell you major problems other owners encountered, you better think twice. I personally think even if the failure is 5%, it make me feel uneasy to own the car long term if I don't get it fix with new parts.
06-19-2019, 08:12 PM | #57 |
Rep 4
Model: 2014 428i, 6 speed manual, May 2014 build date, Germany
Mileage: 29,000 Timing Chain Status: No problems Oil Changes: Every 8000 miles Stop/Start Coded Status: Off Additional info: assuming I don't have any issues before then, I plan to have it changed when the extended warranty runs out at 7/70. |
06-19-2019, 11:57 PM | #58 |
Rep 26
Model: 2013 328i xDrive
Mileage: 66k miles Timing Chain Status: replaced on CPO warranty earlier this year Stop/Start Coded Status: Not coded, but always turn it off Additional Details: took into local BMW dealer with complaint of a whine (wasn't that bad yet imo - https://streamable.com/1hk49), shop foreman listened with the hood up then met me back in the waiting area and said they're going to replace it all and that was it. |
06-20-2019, 02:30 AM | #59 |
Rep 500
Just got my car back today. Also got other issues fix at one go. Below is the breakdown if anyone interested.
Timing chain, guide, oil pump timing chain module, gasket, tensioner and vanos central valve (2 units) + labor: RM 4800 = USD 1200. Another item to change for older car is the turbo oil supply line with valve which cost around RM 900 = USD 225. Fix the thermostat issue which show error in diagnostic program but no error code in iDrive. Also replace engine mounting and front spring strut mounts and damper. Now the car drive like a new car and feel tight and nice. The price above is after 25% discount as long term customer. SA advice me to drive for 2 weeks and bring back for inspection if there is any oil leak. Last edited by pierreye; 06-20-2019 at 09:05 PM.. |
06-25-2019, 12:52 PM | #60 |
Rep 82
Drives: 2012 BMW 328i Luxury Line RWD
Model: MY 2012 328i rwd. February 14th, 2012 build date. Munich. (CPO)
Mileage: 91,326 miles Timing Chain Status: No problems Oil Changes: Every 7k miles since 67k miles, not sure about PO (but it was dealer maintained as per lease arrangement) Stop/Start Coded Status: Not coded, but always turn it off |
06-26-2019, 08:04 AM | #61 |
Rep 82
Here's a peak of my timing chain guide through the oil filler hole at 91,328 miles. February 2012 Munich build.
No problems so far. IF the guide were to become a problem, would there be warning signs visible from the oil filler hole? https://www.dropbox.com/sh/6u5rxzlmj...JozcgitPa?dl=0 |
06-26-2019, 02:43 PM | #62 | |
Rep 3,680
06-26-2019, 09:50 PM | #63 |
Rep 500
You can try to use a borescope to take a look. Especially at the joint where the plastic will most likely break. You can refer to the photo I take on the possible point of failure.
06-27-2019, 06:38 AM | #64 |
Rep 3,680
Where is that joint in relation to the front of the engine? As in, if I were to buy a borescope and take a look, where would I want to be pointing the thing?
06-27-2019, 08:30 AM | #65 |
Rep 191
Disclaimer, I have a boroscope and have tried tirelessly to get an angle on the most common area of failure. It is near impossible. There is a very small space to actually get the boroscope down past the valve cover at which point you would need to have the camera angled 90 degrees to properly see anything. Which is of course impossible once you have the boroscope down past the cams.
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
06-27-2019, 08:38 AM | #66 | |
Rep 3,680
