11-29-2013, 09:25 PM | #1 |
Rep 674
aFe N20 Downpipe Fitment Issue
So I went to install my brand new aFe downpipe on my 2013 328i (N20) and everything went fairly smooth until the very end where you need to slide the factory exhaust over the tip of the downpipe and then clamp it down. The issue that I ran into is that the last small 3-4" piece of the downpipe appears to be just slightly too large and I cannot get the factory exhaust over it (see pics attached). Just wanted to see if anyone else has seen this issue before as it really surprises me that I would run into an issue with probably the simplist part of of the construction of the downpipe. You would think that checking this part of the fitment would be part of the Q&A check before they are shipped out.
11-29-2013, 09:49 PM | #2 | |
Rep 11
11-30-2013, 07:36 PM | #5 |
Rep 10
For over 400.00, that's ridiculous. They advertise "hassle free installation". It's supposed to be slip fit correct? Then it should fit, albeit a tight fit. I'd give them a call.
11-30-2013, 09:04 PM | #6 |
Rep 674
I 100% agree and am really pissed off. I'm probably going to get a tailpipe expander from autozone to try to stretch the factory exhaust pipe just the tiniest bit to get this damn thing in there. I'm already down 4 hours of my own time which will probably grow to 6 or 7 tomorrow. REALLY disappointed in aFe's quality control on this one...
11-30-2013, 09:05 PM | #7 |
Rep 674
12-01-2013, 03:14 PM | #9 | |
Rep 53
But they were making jokes about the plug&play, simple bolt on as advertised, LOL.... Mine wasn't from AFE, I bought it from evolution race werks, and sent them an email describing the issue. |
12-01-2013, 04:48 PM | #10 | |
Rep 152
I'm afraid I have this very same issue. Gonna send them an email asap. I intend to install it myself but if it comes like yours I'll have to go to a exhaust shop to get it installed properly. I can't understand how a flaw like this is ignored by quality control. |
12-02-2013, 09:25 PM | #11 | |
Rep 674
All that I can say as a word of advice is before you do anything, unbolt the factory exhaust from the downpipe first and remove the 4 bolts that mount it to the frame (you have to do this anyway and it will only take you 5 minutes). Then slide the exhaust out and over a few inches so you can test fit the new downpipe into the factory exhaust. If it slides in flush, proceed with the install, if not, consider contacting aFe for advice before dealing with what Im dealing with. This install should literally only take about 1-2 hours depending on the tools you have available, I'm about 8-10 hours vested at this point, and still not done |
12-03-2013, 12:41 AM | #12 |
Driving Mika all over California.....
57
Rep 619
Sounds like typical aFe shenanigans. I have the Scorcher module and it throws engine codes like a madman. I called them about this and they will not return my calls. I will search else where for future parts purchases.
2008 E60 M5 Sepang Bronze Metallic, gloss black grills and gills, LED side markers, 12mm spacers all around, stud conversion kit, custom exhaust with Magnaflow mufflers and x-pipe.
12-03-2013, 11:14 AM | #13 | |
Rep 389
I sent AFE an email asking about codes that can be seen during maintenance and the replied leading me to believe I can expect no codes |
12-03-2013, 11:32 AM | #14 |
57
Rep 619
Here are the codes from the dealership. They are mostly computer confusion due to increased power or wheel spin. These aren't terrible by products, but I am not too happy that my car goes into limp mode as a result.
12-03-2013, 12:33 PM | #15 |
Rep 389
It's actually not good customer service that you are not getting support. I will point the sale guy who contacted me to this thread. Safe to say i am not very comfortable going for AFE ATM perhaps stage 1 BMS should be the way for me.
12-03-2013, 02:05 PM | #16 |
Rep 3,566
It's been in my car since 25th Feb '13 and hasn't missed a beat. Was removed for one day so BMW could carry out first service. They didn't know about the BMS as all diagnosis data/codes were clear.
The BMS went straight back in after I drove my car home. No issues to date.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
12-03-2013, 03:33 PM | #17 | |
Rep 389
In my country the best fuel we get is RON 95 equivalent to us 91 . Do you think I will benefit from BMS stage 2 or shall I stick to stage 1 |
12-03-2013, 09:04 PM | #18 | |
Rep 3,566
We also have RON95 & 98 as well amongst other fuel mixes. I have stuck with Stage 1 as Stage 2 is still in Beta form and personally, I prefer to wait until S2 is out of beta. Others on this forum have S2 and love it. With the electronic waste gate (late 2012 build N20 engines onwards), the power & torque boost over S1 is not as high as with the solenoid controlled waste gate. Until BMS find a solution, I'm happy with staying put. S1 is a great jump over an already impressive stock performance.
12-03-2013, 09:06 PM | #19 | |
Rep 674
On a side note I suppose, spoke to aFe technical support today and theyre going to send me another exhaust clamp to see that that does the trick. I dont have high hopes at this point but I guess we'll see. |
12-04-2013, 02:05 AM | #20 | |
Rep 389
I really hope it works out with the new clamp, keep us updated when it arrives |
12-04-2013, 07:51 AM | #21 |
Rep 53
I really don't think a new clamp will do the job.... the problem is the final section's diameter of the DP. It HAS to be thinner so it can go inside the exhaust...
12-04-2013, 08:46 AM | #22 |
Rep 662
I would tend to agree with MCD.
I think the clamp will be a NO-GO to complete the installation correctly. Just judging by the pictures you posted, I imagine that even if the clamp is 4"-8" in length, and is REALLY torqued down on the DP & pipe, the exhaust will leak like a siv. Hoping for the best, but expecting the worst (with this 'fix')...keep us posted. |
