BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Stock F30 335i Axle Back Exhaust Muffler Modification and Dissection
      03-22-2014, 02:15 AM   #89
EB_F30
Drives: 13' M Sport 335 6MT
TurboM, I am curious what tips those are too. Is it just the picture or are they different bigger tips?
      03-22-2014, 06:25 AM   #90
TurboM
TurboM's Avatar
Drives: 2018 F82 M4 ZCP
Originally Posted by EB_F30 View Post
Thanks! Yeah, Im not paying that...I'll be on the look out.
Look on eBay. You can probably get one for about $75 shipped.
      03-22-2014, 06:27 AM   #91
TurboM
TurboM's Avatar
They're the same factory 335 tips in both videos, must be the lighting.
      03-22-2014, 08:36 AM   #92
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Ah I see. Yeah they look much bigger in the 1st Video.
FBO-PS1 and stuff
      03-23-2014, 05:57 AM   #93
Krelle
Denmark
90
Drives: M2C
Did any of you close all holes in both chambers 1 & 3 ?
Thank you for all the info
/ Krelle
      03-23-2014, 07:55 AM   #94
TurboM
TurboM's Avatar
/ Krelle
That's exactly what I did.
      03-23-2014, 09:02 AM   #95
Krelle
Denmark
90
Drives: M2C
Tanks TurboM,
I'll try and copy that and plug the second hole into the Helmholz chamber as well.
I have easy access to some gear and the plug can easily be removed again. This is only a test as my mind is 60-40 against getting a positive result. We'll see when I get to it.
/Krelle
      03-23-2014, 09:18 AM   #96
TurboM
TurboM's Avatar
Tanks TurboM,
/Krelle
I don't think there will be any surprises as to what it will sound like if you completely plug everything up in side the muffler. You're basically just doing a muffler delete with the canister still in place. Not sure I would bother if I were you, just my $.02...
      03-23-2014, 10:21 AM   #97
Krelle
Denmark
90
Drives: M2C
you might be right, but I'm corious to see what happens and if it has any effect.
For sure I will not accept any drone like when deleting it.
/Krelle
      03-23-2014, 07:33 PM   #98
Jadar
Dejan
Jadar's Avatar
Serbia
1753
/ Krelle
Yes that's what I did. They were all welded shut.
FBO-PS1 and stuff
      03-23-2014, 07:35 PM   #99
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Tanks TurboM,
/Krelle
Yep I agree, I'd just weld the small perforated tubes as the result is already proven. It may be a tad bit louder with that second hole plugged up but not sure. I mean if he does it it would be great to se or hear what it sounds like. Keep us posted.
FBO-PS1 and stuff
      03-25-2014, 02:13 AM   #100
twelve535i
twelve535i's Avatar
Drives: 2015 X5 35i M Sport
I've been really interested in this type of mod since I saw a thread where M3's were having it done.
What I'm not quite clear on is how sealing up all the holes in the muffler produces less drone and a different sound than straight piping.
      03-25-2014, 03:03 AM   #101
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Because the Helmholtz chamber is still in tact.
It's louder but not to the point where it will emit unbearable drone.
FBO-PS1 and stuff
      03-25-2014, 07:37 AM   #102
TurboM
TurboM's Avatar
and more importantly (for me) the exhaust note is almost inaudible while cruising. It does get much louder once you pass about 50% throttle. This is definitely not the case with a straight pipe.
      03-25-2014, 01:58 PM   #103
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Spot on.
FBO-PS1 and stuff
      03-25-2014, 02:53 PM   #104
Anderw
Anderw's Avatar
Drives: F80 m3
cool to see something like this ! always thought the E9x M muffler mod sounded great!
      03-25-2014, 03:47 PM   #105
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Yes it's where I got my idea initially. So I was very optimistic it would work.
I believe the guys that were doing it on e9x M3 were from Canada. They charged $400 plus your muffler as a core. For the sound it's a pretty good bargain, especially with how much car backs cost now days.
FBO-PS1 and stuff
      03-25-2014, 04:18 PM   #106
twelve535i
twelve535i's Avatar
What confused me at first was the fact that the tubing in chamber 2 has no holes, so I didn't see how that could drown out any noise.
Now that I look at the picture again, it appears that there is an additional pipe the runs from chamber 1 into 2 that you have no touched. Is that correct?
      03-25-2014, 04:53 PM   #107
pkimM3r
pkimM3r's Avatar
205
So how are you going to spot weld on the underside?
Wouldn't having a Meineke guy with tubing make a straight through tube design be cheaper? that's essentially what's being done...no?
In chamber 3 yes that would be the way to go, just cut and replace with a tube and weld it back.
The difficult part would be re fabricating the section in chamber 1. It's not round, it's very much oval. Not saying its not possible, but I doubt it be cheaper then just welding each hole.
The underside plan is to open the muffler even further with my angle grinder so I have access to the underside.
I'm not saying this is going to successful but if I close off the perforated tube there will be a change in the exhaust note. I'm not even sure if it will be a good sound, it may be the most annoying thing we ever hear....but we'll all find out soon
Just wrap it in heat shield and safety wire them down. Thats what i did on mine.
      03-25-2014, 05:20 PM   #108
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Yes that is 100% correct. There is a smaller tube leading into the Helmholtz chamber that still slows some of the sound to drown out. This is naturally designed by BMW to severely reduce drone.
Someone in an earlier post mentioned they were planning on plugging this hole as well. I advise against this because essentially what you will just end up with is straight pipes. No sound can escape into the Helmholtz chamber hence it will drone and defeating the purpose I set out for.
At this point if he's gonna plug up that hole as well you may as well cut the muffler off and just straight pipe it.
FBO-PS1 and stuff
      03-25-2014, 05:47 PM   #109
eyim1988
eyim1988's Avatar
98
Drives: 2022 BMW M4
2022 M4  [0.00]
Thats why i only spot welded half the holes. Ill do a better video soon
Current: 2021 X3MC
Past: 2013 bmw 335i, 2011 bmw 335i coupe, 2016 bmw m3
      03-25-2014, 06:44 PM   #110
twelve535i
twelve535i's Avatar
Thanks man.
I might try it out on my own car, but I have two mufflers on my f10, and zero experience. ha ha
