02-17-2024, 06:25 AM | #1 |
Rep 1
Horrible Rattling Exhaust (mid carriage)
Hi there
Out for a drive today in the 2014 F30 320D sportine when a nasty steel on steel rattling kicked off. Made it to a mechanic and we had a look. They say the corroded bolt in the image is the issue. The whole exhaust was rattling down against a steel bracket amidships. I think a bracket may be missing from The area below the drivers seat? Anyone experienced this and any tips on getting the right fix? Thanks 🙏🏼 |
02-17-2024, 08:59 AM | #2 |
Rep 182
I had the same issue with my brand new 340, dealer-installed MPPSK.
They had mounted the midpipe slightly wrong and a a screw was touching the heat shield, if I remember correctly. The issue was gone once they corrected the fitment of the midpipe and I've never experienced that problem again.
340 xdrive 6MT - HJS catted DP - MPPSK - TU HPFP - 550i clutch - VAC monoball control arms - Eibach springs - H&R antiroll bars - AutoSolutions SSK - Brembo HP2000 pads
Corvette C6 Z06 Z07 |
F30Farang0.00 |
02-29-2024, 04:05 PM | #3 |
Resident Fool
Rep 26
AA dp installed and (because of slightly different angle) under load, exhaust would make contact with heat shield and x-brace. reclocked dp a little and used a couple small washers on x-brace, zero problems thousands of miles later.
Last edited by QUESTOR; 02-29-2024 at 04:06 PM.. Reason: i never learned how to read and write. |
