06-05-2016, 02:36 PM | #1 |
Rep 83
Need Advice on a dashcam
Need a dashcam. Was wondering if anyone can provide any insights on this one
http://www.ebay.com/itm/WIFI-HD-1080...wAAOSwlfxXGHxs It looks like this one but wayy cheaper. http://www.kammu.com/shop/dash-cam/f...080p-g-sensor/ Looks like a clean finish but dont know about the quality. I am open to suggestions if anyone has a small dash cam, dont need a screen as most can be paired with the phone. I understand a fuse tap would be the best mode for installing these cant seem to find any cams with 12+ hour battery life. Thank You. |
06-05-2016, 02:48 PM | #2 |
Rep 141
Please update if you do get it it sounds interesting
I currently have the Blackvue Dashcam is pretty good . The only thing is that if you used the app it takes for ever to load the videos haha Good luck and dont forget to update |
06-05-2016, 02:50 PM | #4 |
Rep 1,907
06-05-2016, 09:57 PM | #5 | |
Rep 261
06-06-2016, 08:59 PM | #6 |
Sustinendum Victoriam
80
Rep 349
06-15-2016, 08:58 AM | #7 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
I have the thinkware 750 and x500 rear cam on both my vehicles, I love them!
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
06-15-2016, 10:25 AM | #9 |
Rep 1,056
I'm using mobius C lens for the rear and Mini 0803 for the front.
The mini 0803 battery is dying now due to summer heat. Just ordered a Joovuu X with super cap. Hope it will work well.
07-01-2016, 10:14 AM | #11 |
515
Rep 1,063
I honestly forgot how I did it lol. Pretty sure I used the power for the 12v underneath the radio, both my radar and cams are hooked to it.
07-06-2016, 08:32 AM | #12 | |
Rep 2
Hope this helps! |
07-06-2016, 08:41 AM | #13 |
Rep 2,046
Lucas is the way to go .
07-12-2017, 05:03 AM | #15 |
Rep 565
BMW has a dashcam called "BMW Advanced Car Eye". It is supported by BMW and won't drain you battery even when you use it to record any events while the car is turned off and parked.
07-16-2017, 02:17 PM | #16 |
Rep 125
I can recommend the Thinkware F770. The good thing about it is that it has an inbuilt configurable shutoff voltage controller, so it will not drain your battery in parking mode and you can configure it via the app. For the Blackvue people usually buy an external box which needs setup with dip switches.
It's not a perfect cam as mine has buttons which rattle, but that's easily fixed. Installation is easy, all of the trim pieces simply pull out and you can do it yourself. Only thing to note is that the supplied cables are too short to reach the fuse box in the trunk so you'll need to solder a few wires to extend the cable. See these threads for more info: http://f80.bimmerpost.com/forums/sho....php?t=1277324 http://f30.bimmerpost.com/forums/sho....php?t=1298756 |
illusionx18.50 |
