02-15-2017, 06:20 AM | #1 |
Driver
465
Rep 1,002
Sport vs Sport+ question
I drive a 340i M Sport with standard (704) non adaptive suspension. Is the only difference between the Sport & Sport+ settings the switching off of DSC (traction control) or does it affect throttle/steering responses even further?
02-15-2017, 10:37 AM | #3 | |
Rep 1,472
True, but to OP, I would suggest to find an empty parking lot on the day roads are wet (can't be that hard in UK) and try it for yourself. Dry roads, no issues, on wet, a lot easier to lose the rear end in Sport+. This is nearly impossible to do, even on snow in other modes. You owe it to yourself to try this, it can be fun, but also terrifying how quickly rear end can snap on wet in Sport+ (especially with run flats). |
Wires1645.50 |
02-15-2017, 10:42 AM | #4 |
Rep 5,997
It feels noticeably more aggressive in sport+ than sport. Transmission holds gears longer and throttle response is quicker. I use it all the time. The traction control is dialed back somewhat as well. It's great even at low speeds in rush hour traffic. I still find myself using the paddles from time to time tho.
02-15-2017, 01:59 PM | #6 |
Rep 1,056
everything is same between sport and sport+. you get more wheel slip with sport+.
02-15-2017, 02:37 PM | #7 |
Rep 4,724
This! Nothing else changes
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
tturedraider4974.50 |
02-15-2017, 03:22 PM | #8 |
Rep 6,239
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
Dynamic Traction Control turned on is the only difference.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
Bbb34730.50 |
02-16-2017, 01:25 AM | #10 |
2JZ-GTE
3038
Rep 3,992
With sport plus you're allowed some slippage as others have noted. I love it because the amount of slippage the car allows depends on its mood. Sometimes it lets you move the rear end out a little while clearly abusing the throttle. Other times it let's the rear go sideways. sport plus allows one to more easily crash the car, Especially in less than ideal conditions. I always thought electronics would catch the car. Played with it on the track and no. .
Bbb34730.50 |
02-16-2017, 07:12 AM | #11 | |
Rep 15,858
Bbb34730.50 Torque of the Devil578.50 |
02-16-2017, 07:22 AM | #12 |
Fool
1857
Rep 3,542
If you have sport set up so the chassis is in comfort, putting it in sport+ will make the steering heavier too. If you leave the sport set up so that chassis is sport as well as drivetrain, it won't make any difference to the steering, only the traction control as stated above.
02-16-2017, 07:25 AM | #13 | |
Rep 1,472
What someone assumes to be "a bit of slippage allowed" isn't as easy to predict on wet or snow covered roads. |
eluded3038.00 |
02-16-2017, 09:22 AM | #14 |
Rep 57
I have a fuzzy recollection that on automatic transmission cars, if you put it in manual shift mode in Sport+, it'll bounce off the rev limiter instead of automatically upshifting at redline. Does it do that in Sport too, or is that also a Sport+ difference?
02-16-2017, 09:46 AM | #15 |
Rep 5,997
Not sure about that. Best way to know is to try it t in both modes. When I use the paddles it is pretty much like driving a manual but I've never tested if it will shift at redline or stay in the gear.
02-16-2017, 09:49 AM | #16 | ||
Rep 5,997
02-16-2017, 09:58 AM | #17 |
The Wolf
247
Rep 987
Drives: stuff
I prefer holding traction as that with my adaptive susp car tightens the wheel, the suspension and fully disengages traction control... while leaving the throttle normal as it is in comfort.
however you don't get the overrun and decel burbles/pops from the exhaust unless in sport+ which has the annoying oversensitive throttle.
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
02-16-2017, 10:04 AM | #18 | |
Rep 1,472
Not sure what you meant by "shift with paddles", those of us with manual, don't get any additional traction in Sport+ I drive on snow 4+ months every year, and in other modes, it's nearly impossible to lose it. In Sport+ it ranges from as you say a "wiggle/fun" to "oh, is that my rear end that just blew past me" I guess my point (in my experience) is that it's tricky to predict exactly how much assistance you will get, so in new car when you start using Sport+, assume "none". |
02-16-2017, 10:13 AM | #19 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
02-16-2017, 11:04 AM | #20 | |
Rep 57
For the most part, I find the more relaxed stability control of DTC to be a better fit for mildly slippery streets. The only exception is when things start to get too cold and too icy, where I find these Sottozeroes don't work as well as other winter tires I've used in the past, and I need all the help I can get to keep the rear end from passing me. |
02-16-2017, 11:22 AM | #21 | ||
Rep 5,997
