09-27-2019, 08:53 PM | #1 |
Rep 180
Safe to use IPA on ceramic coat?
Hello. Can I do spot cleans on my ceramic coat using a 25% IPA spray + wipedown? What do you guys recommend for spot cleaning (tree sap, bird droppings, dead bugs, finger prints, etc)?
TY |
10-01-2019, 09:33 AM | #3 | |
Rep 202
Maybe consider as the perfect solution getting something like the Gtechniq bird dropping wipes and also their quick detailer as this is developed to be used in conjunction with ceramic and crystal coatings |
Cpatel39.50 |
10-03-2019, 07:12 AM | #4 |
NewFinishColumbia/detailer
604
Rep 2,096
I use ONR for this type of situation. I use the spray detailer dilution unless I'm doing a wash and then it's the normal 356:1 ratio.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
10-04-2019, 09:49 AM | #5 |
Rep 906
IPA's are for drinking
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired 2018 330i Sedan M-Sport - Retired 2015 428i Gran Coupe M-Sport - Retired |
10-04-2019, 02:46 PM | #6 |
Rep 6,696
Drives: F30 340i
where are you guys learning this from? using ipa for spot treatment is absurd. ipa wipe downs are used normally for prepping surfaces PRIOR to an lsp so why would you use it on TOP of one? makes zero sense.
take the advice of items like ONR/waterless/detailers. if you question these products in terms of scratching your paint or are nervous with the amount of contamination on your paint then you've answered your own question...aka wash your car. |
10-14-2019, 03:32 AM | #7 |
Rep 3,898
Use a Quick Detailer for spot cleaning, not IPA!
From my research - IPA is only recommended to be used as 10-15% and not as a daily cleaning fluid! It is typically only used to more aggressively strip down wax/sealants or other oil-based contaminants. Not for daily hygiene. No need for that either.
