BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Rheingold 3.47.10 issues
proTUNING Freaks
      04-03-2015, 06:56 PM   #1
stormlv
Human
Switzerland
932
Drives: Yes
Hi there,
Sorry if this was asked before, but I have an issue with getting Rheingold to work.
I managed to install it and to get it running.
I even managed to have it see my car in the connection manager (I see the VIN/ IP assigned, etc).
The problem is that as soon as I double click on it to set up a connection, I get an error "Unable to identify vehicle" :|
Any thoughts on what the problem is?
Thanks!
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute
Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album
2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album
      04-07-2015, 02:55 PM   #2
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
did you go to the setup and select e-net?
i think the default is k-can
      04-07-2015, 03:05 PM   #3
stormlv
Human
Switzerland
932
Drives: Yes
Sorry, I should have updated the thread, but I've since fixed the issue.
Apparently in the TesterGUI.config the Ediabas path was incorrectly set up.
Once I pointed it to the correct folder everything worked.
      04-08-2015, 08:46 AM   #4
Coolala
Japan
38
Drives: 2013 F30
Hi,
I have the same issue as you, can see VIN and IP assigned, but prompt me cannot find vehicle and check "ignition on" when making connection. Of course I have ignition on already.
I cannot find TesterGUI.config like you but there is a folder called TesterGUI under C:\Rheingold . Unter C:\Rheingold\TesterGUI\bin\Release there is a file called ISTAGUI.exe.config and ISTAGUI.exe . The .exe file is which I used to start the program. Do you mean modify ISTAGUI.exe file for the correct EDIABAS path?
I'm using Rheingold 3.47.30 ....
Thanks in advance!
      04-08-2015, 08:58 AM   #5
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
i was never able to connect to the car using Rheingold using the ENET option.
Originally, after entering my VIN, and having all the info show up, i clicked on Connect to car. Another dialog shows up listing my car there with the status showing "Free", but then the button to do the actual connect never gets activated (shows as greyed out), so it just stayed stuck there.
I had to go into the Settings (click on Wrench icon at the top) to configure the connection. I selected VCI config. , then i selected Ediabas standard.
Then back at the normal screens, instead of entering VIN, I clicked the 2nd block that says "Read Out Vehicle Data" > "Complete Identification"
After that, it connected to the car, and all my Control Units were displayed in that tree/graph.
      04-08-2015, 09:00 AM   #6
stormlv
Human
Switzerland
932
Drives: Yes
Originally Posted by Coolala View Post
Hi,
Thanks in advance!
Yes exactly, you're right, I was talking about the ISTAGUI.exe.config in the TesterGUI folder.
In my case there was a line which was commented out, related to the Ediabas path.
It it's like that for you as well, remove the <-- and --> surrounding that line.
I'll check when I get home to give you the exact one.
      04-08-2015, 10:46 AM   #7
Coolala
Japan
38
Drives: 2013 F30
The config file content like this:
<add key="BMW.Rheingold.ISTAGUI.BinPathModifications" value="..\..\..\Ediabas\BIN"/>
I need to remove "<!--" and "-->" , right? It looks like the remark syntax....
Thanks in adavance!
      04-08-2015, 11:21 AM   #8
stormlv
Human
Switzerland
932
Drives: Yes
Yup, that was it for me.
      04-08-2015, 12:15 PM   #9
Coolala
Japan
38
Drives: 2013 F30
Thanks in adavance!
Hi stormlv,
I've just get it fixed. I can connect Rheingold without any problem. There is no one mentioned about this.
Thanks for your advice!
      04-09-2015, 12:54 AM   #10
stormlv
Human
Switzerland
932
Drives: Yes
Hi stormlv,
Cool, glad you solved it.
I spent a bit of time trying to solve this issue.
The error message given by Rheingold is very cryptic. Only the logs helped a bit. They were mentioning that they couldn't load api32.dll, a file that I traced back to the Ediabas folder.
      06-24-2015, 10:17 PM   #11
steelerfan
steelerfan's Avatar
163
Drives: 2017 X5 Silver
i'm sure this has been asked 100 times... but where can i get the Rheingold software?
      08-13-2017, 08:25 PM   #12
michaelyeg
Drives: 2014 BMW 328i xDrive
Latest version I can find online.
      08-13-2017, 08:28 PM   #13
michaelyeg
I have the same issue. Changed Interface to "ENET" in EDIABAS.INI under ./Rheingold/Ediabas from "REMOTE" and it works.
