07-17-2014, 09:39 PM | #23 |
Rep 1,267
Those are quick shifts.. Almost twin clutch speed. I need to do this.
2016 Black Sapphire 328i | M Sport Pkg. | JB+ | Premium Pkg. | Heated Seats | Driver Assist Pkg. | Navigation | Misc. Coding | 35% Ceramic Tint
Past: 2014 Black 320i | Sport Pkg | BMS Stage 1 |
07-17-2014, 10:48 PM | #24 |
Rep 4,976
It is. It's amazing. Shifts almost as quick as my wife's fully loaded 335 m sport and definitely close to my brother M235i. (Yes I have a very BMW family). Definitely worth the coding.
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
07-18-2014, 01:21 AM | #25 | |
Rep 1,892
The procedure I use to code SAT is as follows: 1. Change option 205 to 2TB in the FA. 2. VO Code the EGS, ICM, and [B]KOMBI. I don't fuss with all of the FDL codes for this; too many changes and places to make a mistake. Doing the above provides SAT plus Sport+ mode and it's display in the instrument cluster. |
07-18-2014, 08:08 AM | #26 | |
Rep 906
EGS/3000/SPORTSCHALTER EGS/3000/SPORTSCHALTER_ALT Changing the FA is what I was talking about earlier. That I did not do, but probably will after I get the car back. So this may be a stupid question, but how do you change 205 to 2TB in the FA? Finally, what are the options that should be changed in KOMBI and ICM? I have DHP, so Sport+ should be activated already. Thanks!
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World Last edited by capt_slow; 07-18-2014 at 08:15 AM.. |
07-18-2014, 10:29 AM | #27 | ||
Rep 1,892
To fully enable SAT, do the following: Quote:
07-18-2014, 01:39 PM | #28 |
Rep 906
Is there a tutorial or instruction to change 205 to 2TB? I'm still sort of new to coding and all I have done so far is FDL coding and ticking a few options here and there.
2020 i3 Rex: Capparis White, Giga World |
07-18-2014, 02:15 PM | #29 |
Rep 40,645
You need to read this:
E-Sys - How to change FA in F-series car.pdf: http://www.bimmerfest.com/forums/att...6&d=1338725691
07-18-2014, 02:36 PM | #30 | |
Rep 906
I just read the doc and got a question for either you or Frogman. Will changing the FA also VO code the three modules in question as well?
07-18-2014, 03:40 PM | #31 | |
Rep 1,892
Once you change the option code(s), go back to the coding screen, using the newly edited FA. Make sure the SVT is read in and the FA is active (like you would when you FDL code). Right click on the ECU you want to VO code (e.g. EGS), and select Code. Repeat for each ECU (ICM and KOMBI). The will set the default values for the ECU based on the FA/VO; hence VO Coding. If you had previously custom FDL coded any of the ECU's you just VO coded, you will need to re-FDL code them as VO coding will clear your custom settings. |
07-18-2014, 03:44 PM | #32 | |
Rep 1,892
You might also want to disable the updating of the VCM and MSM before you do any FA changes so that they are not written back to the car. See this post for details: http://f30.bimmerpost.com/forums/sho...5&postcount=32 |
07-18-2014, 04:57 PM | #33 |
Rep 906
Perhaps there wasnt much wisdom to what I just did...
So I got a little impatient and coded SAT to my 320i loaner using the instructions provided by Frogman and Shawnsheridan. It looks good, the engine turns, and tranny shifts. I'm about to take it for a test drive, but I took a peek at all the coded modules and the relevant settings for BKOMBI, EGS, and ICM have changed to their SAT values. Thanks for all for the help!
07-18-2014, 04:59 PM | #34 |
Rep 40,645
I code all my loaners.
07-18-2014, 05:17 PM | #35 | |
Rep 1,892
07-18-2014, 05:19 PM | #36 |
Rep 40,645
...and if they have Nav in them, it's never activated....so I activate it too.
07-18-2014, 05:28 PM | #37 |
Rep 1,892
07-18-2014, 09:02 PM | #39 |
Rep 40,645
PM sent.
07-24-2014, 01:25 AM | #40 |
Rep 23
I have some bad news for you guys. I ,ve tested SAT mode it actually produces slower 1/4 times, maybe without reflash it might be ok, but I started doing some serious testing (as in racelogic, datalog and gopro filming) high octane with JB4 stage 2 and the car was actually .5 seconds or more slower in this mode.
My idea is that the tune is not capable of keeping boost steady with the quicker shift points and there is actually some weird transmission snap/hesitation that slows the car down quite a bit at high rpms 5500 -6000rpm. This with the reflash on, its kind of like knocking at high rpms. I reverted back to the normal DS capable shifting and the car is faster, smoother shifts and the turbo (JB4 stage 2 enabled) spools nice and smooth at high rpms. So, If you like quick downshifts and do not care about peak horsepower at high rpms do SAT. If you like a broader stronger smoother power curve that actually is quicker (with reflash) keep stock settings, and just enable sport+ if your 320 did not come with it. let me know your comments... |
07-24-2014, 05:04 PM | #41 | |
Rep 4,976
07-27-2014, 07:04 PM | #42 | |
Rep 18
07-28-2014, 11:42 PM | #43 | |
Rep 23
08-06-2014, 02:32 PM | #44 |
Rep 1,267
Wait a minute, what are you guys saying? It's worse with SAT? What you describe does not sound good. I mean, what exactly is being said here? That the car is slower overall, or that it hiccups under WOT or what?
Past: 2014 Black 320i | Sport Pkg | BMS Stage 1 Last edited by Kafkaesque328; 08-06-2014 at 02:40 PM.. |
