02-05-2017, 12:47 PM | #23 | ||
Rep 1,029
Here in L.A. I get my tires from America's tires, they seem to have lower prices then tirerack.com Good luck!!
Current: 2023 G26 430i GC San Remo Green / Red Sensatec M Sport.
Previous:2020 G20 330i M Sport (MG/BLK), 2018 F36 4GC LCI (SRB/NB), 2015 F36 4GC (MG/CR), 2012 F25 X328i (JB/CB), 2009 E90 328I sedan (SG/SB), 2004 E46 325I sedan (SG/BLK). |
02-05-2017, 07:21 PM | #24 |
Rep 465
Whats roadforce balancing and thanks I will. Wondering if there is specific wheels to buy for hard roads. Are should I beef up the tires?
02-05-2017, 08:04 PM | #25 |
Rep 1,342
02-05-2017, 08:34 PM | #26 | |
Rep 2,196
What is road force balancing: https://www.youtube.com/watch?v=DQxVAssnbp8 Some BMW wheels are "softer" than others - E30 bottle caps, for example, would bend all too easily. Run-flat tires have a sturdy sidewall, but the lower profile/aspect ratio does put the wheel in harm's way on bad roads.
02-06-2017, 09:07 AM | #27 |
Rep 69
Dealerships srv dept money grab..
Could you have bent wheels? Very likely (NY/NJ roads.. with run flats and low profile tire sidewalls.. = only matter of when..) but bent wheels will vibrate. Are your tires really that low? (Srv dpts just add alignment with tires.. Measure your tirestread if it is still within lease returns limits, order a tire/wheel package on tire rack and keep oems for lease return |
02-06-2017, 09:54 AM | #28 |
Rep 1,329
Many good points here.
Yes, look for used or remanufactured OEM wheels if they are in fact bent. If you can't feel any vibration in the steering wheel the fronts are fine and you can either sit in the back and feel for vibration in the rear, or have the rims spin balanced and visually checked or have a professional shop measure the runout to see if the rears are ok. As long as the car rides smooth they are not going to check this at lease turn in. If you have only 1 year until lease return, you could probably skip the alignment unless the current tire wear is significantly uneven - a sign the alignment is far off. If needed, anyone with the right equipment can perform the alignment and install tires. I would look for used BMW approved runflats online or on this forum to save the cash and the hassle of swapping tires again in 1 year. These are all thing a standard warranty - even a great one - do not include.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
02-06-2017, 11:03 AM | #29 |
Rep 1,572
In addition to the good info above and depending on the actual Continental tires you currently have, most of them have some degree of wear warranty. assuming you don't have abnormal wear due to road damage or bad alignment and since you have about 17-18 K miles on your tire you may be able to get a prorated discount on new Continentals.
I dont know how it works for a lease vehicle, but may be worth talking to a local shop that handles Continentals or contact Continental directly http://www.continentaltire.com/ Check the bottom of the page for: Customer Care Email Customer Care Phone |
02-06-2017, 11:05 AM | #30 | |
Rep 465
Plus I just got a rim fixed and alignment last time I took my car in. Which was in the fall. |
02-06-2017, 11:05 AM | #31 | |
Rep 465
02-06-2017, 11:11 AM | #32 | |
Rep 465
Sounds good. |
02-06-2017, 11:13 AM | #33 | |
Rep 465
alignment, damage, f30, rims and tires |
