07-11-2016, 05:04 PM | #23 | |
Rep 7,047
My service writer says he opened a "case" with BMW regarding the issue, but BMW claims there haven't been many reports of this so they don't have an answer. Well, it seems there are, but it could be that many are not making their service writer report it, or customers don't want to bother with it. If our small collection of owners shows a small number of the same issue, then it's likely that many others have this as well and it needs to get reported so that BMW can find the cause and fix it. To be clear, this is not about a high RPM on cold start or warm/hot restart, but the engine "shake" and vibration as the cold start or restart starts to drop around 1000rpm and eventually smooths out as RPM drops to normal. In my case this issue has become worse in hotter weather because I have had a number of "bogs" and stumbles now when starting to drive off just as I add a bit of throttle right off idle. A number of times the engine bogs very quickly and recovers, or the car starts moving with a st...st...stutter and then smooths out. Report this to your dealers service department if you have these symptoms so that we can get BMW on it! Thanks! BMW > They, BMW, are pretty good at getting things sorted, but only after they finally get enough complaints. |
09-29-2016, 04:33 AM | #24 |
Rep 58
I've got this "cold start issue" after I got the power and sound kit installed. Though it was normal due to the new flash until I saw this thread. I'm going to report this to my dealer.
10-07-2016, 01:10 PM | #25 |
Captain Crunch
168
Rep 548
Another data point for this issue, after the MPPSK install the cold start is still present and just slightly worse. The high RPMs last about 5-15 seconds longer than it did before the install.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade |
10-10-2016, 04:09 PM | #28 | |
Rep 146
10-11-2016, 08:43 AM | #29 | |
Rep 7,047
High rpm cold start, and even high rpm hot start, are part of emissions to help heat the cat-con. The complaint I have, as some others do as well, is the "shaking", seeming like a misfire. Also, taking off too soon after cold start or hot restart often results in a big bog/stall. Emissions standards haven't changed since I had my F30 2013 335i w/N55, and that engine did not shake as idle dropped on cold start or hot restart. Also, not everyone with the new B58 is reporting the "shake" problem. Remember, BMW does NOT recommend a "warm up". They recommend that you drive off quickly after you start a cold engine, and simply drive at nominal rpm until the engine warms up. That is emissions related, because idling to warm up an engine is not as efficient as driving. I have the shake issue reported to BMW. The thing is BMW needs to get a number of complaints on the same issue and then they will figure it out. I'm due for my 1yr maintenance this week. I'll see if BMW has s something for this problem I will escalate the issue with BMW as well, because the bog has been a bit scary a couple of times as I'm trying to accel away at a light, or merge into traffic soon after restart, even when the engine has not shake. It's not normal in the least. As for new engine or first year, of course, anything can happen with new products. Issues even happen with 2nd, 3rd and on years of production. I don't expect perfection on any initial run. What I do expect is for BMW, or any auto maker, to correct any problem that arises. BMW Financial expects me to make my payments, I expect BMW to fix warranty issues. |
10-11-2016, 08:46 AM | #30 | |
Rep 7,047
High cold idle start has been used for decades with every car maker. The question some have here is that they notice that even when hot their 340i goes through a similar "cold start" program. The other issue reported here is the engine "shake" during the idle down on cold start and on hot restart. Seems that most have the hot restart idle down, but not everyone has the engine shake. |
10-11-2016, 01:20 PM | #31 | |
Rep 146
My e90 M3 also drove like this during cold starts (sans the loud injectors). |
10-11-2016, 01:39 PM | #32 |
Rep 1,170
I get a "stumble" when I first put car in gear and move it but only during an actual cold start and only on initial throttle application, last's a half a sec or so and then no problem. Done it since new, I don't consider it an issue, more a quirk I attribute to the performance characteristics of the engine.
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
10-11-2016, 02:59 PM | #33 | |
The Wolf
247
Rep 987
Drives: stuff
annoying but we'll see what transpires for this engine in the future, even exhaust flap unplugged this thing is just too quiet out the ass!
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody |
10-11-2016, 03:08 PM | #34 |
Rep 1,170
I'm fixing that Thursday.
10-11-2016, 03:25 PM | #35 |
Rep 146
WAAAAY too quiet. I fixed that with a DINAN exhaust.
10-11-2016, 03:54 PM | #36 |
The Wolf
247
Rep 987
Drives: stuff
I want the MPPSK but I leased it 1 day before that was available, now I have to face the depreciation of putting it on the car I dont' actually own... tough!
10-11-2016, 04:12 PM | #37 |
Rep 1,170
Dang! Tough spot for sure. As happy as people seem to be with it I guess my question would be ... How long is your lease and how deep are your pockets?
10-11-2016, 05:03 PM | #38 |
Rep 146
12-05-2016, 10:34 AM | #39 |
Driver
465
Rep 1,002
12-06-2016, 06:22 PM | #41 | |
Rep 2,825
12-07-2016, 09:32 AM | #42 |
Driver
465
Rep 1,002
Apparently the B58 engine has thermal heat retention insulation so it can retain 'much' of it's heat for 'up to' 36 hours, for improved fuel efficiency and engine health in short run driving situations!! So it seems strange that they all appear to be performing a 'cold start' even when they're warm!!! Makes no sense...
Blubaron791431.50 |
12-08-2016, 03:21 PM | #43 | |
Fool
1857
Rep 3,542
12-08-2016, 06:48 PM | #44 |
Driver
465
Rep 1,002
I was going to ask that exact question (as I haven't got my car yet) but you've confirmed that it doesn't occur during the stop/start cycle... well if it did that would defeat the whole object I guess! My current car, a Porsche Cayman revs briefly just once on start up which I guess is all part of the inbuilt performance car drama (the misses always says why do you do that... and I keep telling her it's not me it's the car) but the revs drop immediately if the engine is warm!! maybe this 340i start up phenomenon is a similar characteristic!
