09-02-2016, 05:25 PM | #67 | |
Rep 35
Funny - that's almost exactly what my salesperson said - in fact he said all his customers will now be getting this option !
w.r.t the VIN Decode What the suggested website came up with in VIN decode was Quote:
09-03-2016, 07:53 AM | #68 |
Rep 521
Drives: 2022 ///M3 6MT
09-20-2016, 01:10 PM | #70 |
Rep 412
Hello Guys
I'm looking for a new 340i, I found a sport line but I definitely want the M sport wheel, can't find any DIY for this upgrade. Some people say that it's a big cost since there is many parts to change beside the sport wheel and airbag. Correct? Thanks
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
09-21-2016, 02:43 PM | #71 |
Rep 486
Are you in Europe? If your airbag is single staged, its not too bad. I've seen the single stage M-Sport airbags go for $300 on ebay. Then you just need to figure out if you need heating, vibration, and paddles for the wheel and you're pretty much set. Shouldn't run you more than $600-700. For us the US, we have to make sure our airbag is dual staged, and the airbag alone will cost $600-$800. All-in, my upgrade cost me $960 (paddles, heated, dual-stage airbag).
FOR SALE - 2014 Scion FR-S 6 spd, 27,000 ODO $17k pm me
2010 e92 Mojave Metallic - farewell old friend /2013 2015 435i xDrive Gran Coupe Sparkling Brown | Cocaine White interior | JB4 | BMS Intake | Wagner Intercooler Evo I | VRSF Downpipes | ER Chargepipes |
09-27-2016, 08:57 PM | #72 |
Rep 521
09-28-2016, 09:22 AM | #73 |
Rep 286
Wouldn't BMW save money by just having one wheel the Msport wheel? I can't imagine manufacturing 3 different wheels is cost effective I guess until they get you with the upgrade pricing
09-28-2016, 09:43 AM | #74 | |
Rep 2,036
Installed yet and any problems/cons?
10-03-2016, 08:47 PM | #75 |
Rep 521
FYI, I contacted getbmwparts.com with the information posted above and they said they could NOT order that piece.
Might be pursuing the re-wrapped eBay option as they can customize to your liking. Just wish I could get the F20 wheel with heating. |
10-04-2016, 02:05 AM | #76 |
Rep 261
I'm not Tuan but I just did a swap. After purchasing our F30 without M sport package, I found the steering wheel leather feels a bit lackluster as I've grown to prefer the soft touch on the M sport.
Bought a wheel off a Lithuanian eBay seller (who somehow claim to ship from UK), but needs customization (add LDW vibrator) so we did the transaction through paypal. Total around $950. The big issue as others have said is the airbag. The seller could sell a US-spec dual-stage airbag for $100 more but I opted for a single-stage as I could always code it. However he was confident his resistor mod would work in a plug-and-play fashion with US ACSM module so I let him have at it. The airbag arrived from Lithuania and I did the swap that weekend. Most of the time was spent shoving a screwdriver in and out trying to locate the latch. Then I reconnected the battery started the ignition. And airbag warning light went up. Looks like the mod didn't work. So I grabbed a notebook and installed E-Sys (This is my first coding session). I disabled the 2nd stage airbag and the vent as per online discussion. Tried again, but still no go. So I called it a night, contacted the seller, and did some more digging. He said he modded the airbag from single stage to 1st stage + fake 2nd stage. He thinks the airbag needs to be modded to present 3 circuits. I finally put 2 and 2 together and realized how the 3 circuits line up with the ECU settings. airbag_fahrer_stufe1 -> stage 1 (EU-spec only has this one) airbag_fahrer_stufe2 -> stage 2 (2nd stage, seller modded) airbag_fahrer_vent -> vent valve (3rd circuit the seller missed) My solution is to re-enable airbag_fahrer_stufe2, leave airbag_fahrer_vent disabled. Cleared existing errors and pressed the ignition and the error went away. So it works, though took a bit of head scratching. Basically the code setting active/inactive should reflect whether the circuit exists (real or fake mod). |
10-04-2016, 05:43 AM | #77 |
Rep 521
@Y0tsuya,
Thank you for the detail! Any photos of your setup post-install? |
10-04-2016, 01:35 PM | #78 |
Rep 261
Nothing special or unique. Just what it would've looked like if I had specified M sport package in the first place. But I have THP and don't care for the body kit. The only thing I miss is the steering wheel.
So to those of you who want to do the swap, just go for it. From my experience, things to watch for are: 1) Part # verification. I use realoem for that. Make sure the new wheel matches old wheel features. The seller should be able to work with you on that. 2) The standard steering wheel airbag is a bit tricky to remove. It took me quite some time (about 1/2 to 1 hour) to feel around and figure out where the latches really are. And you have to pull pretty hard on the airbag at the same time or else you'll never know you've moved the latch. Prepare to get sweaty. 3) Airbag compatibility. Even if you opt for US dual-stage, keep E-Sys handy nearby just in case you need to code. Last edited by Y0tsuya; 10-04-2016 at 01:49 PM.. |
10-10-2016, 08:53 PM | #79 |
Rep 521
For those that have a factory heated steering wheel and then swapped to a wheel that doesn't have a heating element, do you know if you need to code the car to tell it that it no longer has heat or if it will show an error on startup or anything?
Thanks in advance. |
10-11-2016, 07:45 AM | #80 |
Rep 1,114
Thanks for putting this together!
My Ride! : 2015 428i GC (F36) - MSport, Alpine, Black Leather, MBrakes, Adaptive, Sport Seats, Hex. Alum w/Piano, HK Sound, 400m's, Comfort Acc. When I’m not Driving: https://youtube.com/shorts/ViKD_Hj5htE?feature=share
03-18-2023, 01:28 PM | #81 |
Rep 2
03-21-2023, 07:41 AM | #82 |
Rep 1,758
Some 2020 430i M Sport equipped cars have the Sportline wheel with the lower trim that says ///M on it. I looked at one for sale and got the 2018 with the proper M Sport wheel. The '18 also had the options I was interested vs. the '20
2016 428ix, r, 2018 430iC, 2018 330it
