BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Msport Sport+ mode xDrive.
      11-24-2012, 09:24 AM   #1
yellowllewellyn
Drives: 2014 335i xDrive
Does the 335i Msport xDrive have sport+ mode like the sport line? I know that the sport line comes with Eco, comfort, sport and sport+. Does the Msport xDrive have sport+ as well?
      11-24-2012, 09:53 AM   #2
G3333
Drives: F86 X6M
pretty sure all cars have sport+
      11-24-2012, 09:54 AM   #3
howiegu
Member
howiegu's Avatar
Drives: 22%E2%80%99 M440
Yes. Mine has it.
      11-24-2012, 10:20 AM   #4
yellowllewellyn
Originally Posted by howiegu
Yes. Mine has it.
And you have a 335 xDrive? How is it?
      11-24-2012, 10:41 AM   #5
bnekic
I'm pretty excited to try out the xDrive this winter!
      11-24-2012, 11:59 AM   #6
howiegu
Member
howiegu's Avatar
Yes. Mine has it.
Yes. I like it differently than E46 and E90s.
BTW, Sport+ is just Sport with DSC off.
      11-24-2012, 12:08 PM   #7
Jamesons Viggen
I think no line and non Sport cars do not have Sport+, only EP/Comfort/Sport.
'15 Buick Regal "T"(wife)
      11-24-2012, 01:24 PM   #8
yellowllewellyn
Yes. Mine has it.
Good to know. Thanks!!!!
      11-25-2012, 06:13 AM   #9
pkimM3r
pkimM3r's Avatar
205
You can still turn on dynamic handling or turn traction control all the way off. Only thing is the pedals arent as sensitive as when in sport mode. Just press down more!
Is sport+ traction all the way off (hold down traction control foe a few seconds) or is it dynamic handling mode (press button one click)?
      11-25-2012, 06:17 AM   #10
pkimM3r
pkimM3r's Avatar
205
Also the xi for the e90s did not come with the sport suspension. Does the f30xi now come with the sussy or is the msport just a looks thing?
      11-25-2012, 07:09 AM   #11
godfather87
Drives: 2013 335ix
has anyone really tried comparing sport and sport+? I wasn't able to notice much difference between them in regards to speed.....but than again I'm not the best driver..lol
      11-25-2012, 08:54 AM   #12
S-Dot
Drives: 2013 328i xDrive Luxury
You can get variable damping as an option if you choose that option, but otherwise it's the same suspension.
Another poster already noted - there is no difference except for DSC being off.
      11-25-2012, 10:47 PM   #13
yellowllewellyn
Now you said the pedal goes farther in while in sport mode?
      11-26-2012, 01:30 AM   #14
pkimM3r
pkimM3r's Avatar
205
The pedal does not go in more but at the same amount of pedal travel, sport mode opens up more of the throttle. How do i explain this. Pressing down an inch on the gas pedal in sport mode is somewhat like pressing down the gas pedal a couple inches in comfort mode. Now in eco mode....i hate eco mode. Dont use it at all.
      11-26-2012, 06:07 AM   #15
Vitoco
Infidel
Vitoco's Avatar
122
DSC is never off unless you manually turn it off, which you do by pressing the traction button above the drive-mode button. Sport+ is the same as Sport with the addition that DTC is turned on (Dynamic Traction Control). It allows for some more wheel spin before DSC comes to the rescue.
Can u even get adaptive M supsension with Xdrive? Im pretty sure u canīt get the lower M suspension on an xdrive and therefore you shouldnt be able to get the M adaptive. Correct me if Iīm wrong.
      11-26-2012, 08:05 AM   #16
Koer
Drives: F15 X5 2014 Sec. 50i
Sport+ will also change the gear switch positions so that the engine is always revved above 2-3k rpm in auto mode. This is slightly higher than sport mode with 2-2.5k rpm. Try it, when in the highway at a constant speed, switch to sport and then sport+ you will see the difference.
I also feel it will hold on to gears for longer after accelerating. I've seen it keep my engine at 4k rpm after releasing the pedal.
Just my 2 cents after running around in the two modes for a bit
      11-26-2012, 08:35 AM   #17
cardsdoc
Drives: 2016 340i xDrive Msport
You can get m-adaptive on xdrive, it's just not lowered.
2016 340i xDrive, msport, estoril/saddle/anthracite, blk kidney grills, 400m mixed summer, adaptive m, technology, lighting, cold weather, drivers assistance, enhanced usb
      11-26-2012, 08:36 AM   #18
Vitoco
Infidel
Vitoco's Avatar
122
Interesting, will try it.
      11-26-2012, 08:37 AM   #19
Vitoco
Infidel
Vitoco's Avatar
122
There you go
      11-26-2012, 10:19 AM   #20
sean10mm
sean10mm's Avatar
Drives: '13 335i xDrive 6MT ZDH
No mater what the line is, you get sport+ mode if you have any of the following on your car:
Sport Automatic Transmission
Variable sport steering
Adaptive M suspension
      11-26-2012, 10:20 AM   #21
howiegu
Member
howiegu's Avatar
That's because in these two modes, the auto trans will not use 7 and 8th gear. Unless you manually shit.
      11-26-2012, 02:33 PM   #22
elistan
Drives: F30 328i, AP1 S2000
It will if you are traveling at a high enough speed.
