11-15-2017, 09:14 AM | #1 |
Rep 469
Wheel size suggestions on xdrive
What size wheels and tires would you suggest for a f30 xdrive ? I know you have to keep the wheels close to same diameter due to xdrive system .
11-15-2017, 09:21 AM | #2 |
Rep 474
Drives: 2014 328D xDrive
Are you just looking for OEM sizes, or are you looking to change something up?
With xDrive the most important thing is to ensure the overall diameter is the same all around, so you don't damage the transfer case. |
11-15-2017, 09:23 AM | #3 |
Rep 469
Not looking for oem looking for a wider more aggressive set up
11-15-2017, 09:39 AM | #4 |
Rep 474
Well, you can do the OEM staggered setup, again just be sure overall diameter is the same front and back. Staggered puts you at 225/45 front and 255/40 rear I believe.
If you want to go square setup (all the tires the same size) then I think 245/40/18 will fit on the front. Your speedo will be slightly off as the diameter is a little smaller than OEM, but since all 4 tires are the same diameter it won't damage anything. Whether they will fit will depend on the wheel size and offset. |
11-15-2017, 09:53 AM | #5 | |
Rep 469
